| | | Forums66 Topics128,052 Posts1,055,771 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 123 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 123 | Thinking ahead. WHEN (I almost said "IF"!) I finish my truck, I am going to have change the rear end ratio. With the pedal to the floor, if I remember right, it would do about 60 MPH. How expensive is this with the stock closed drive shaft? I think I might have another shaft and gears from a '48 truck lying around somewhere, but it might be the same ratio as I have now.
I have a 58 Transmission, but would like to keep every thing stock.
Was the granny gear set up typical in these trucks, or a minority?
Chuck
1950 Chevy 3100 Deluxe Cab A few Harleys and '76 Triumph Bonneville
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Various venders sell a 3.55 gear set for your rear end which is about the simplest and most inexpensive way there is to get more speed out of less rpm. However, you must remember that you don't have much horse power under the hood. | | | | | Joined: Apr 2010 Posts: 123 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 123 | I should have mentioned that the stock engine was replace with a more modern 235. Not a V8, but more powerful in it's present form than 216 that was in there and has the potential to pump out even more horsepower. Is there a rear end gear set that would be a direct fit from a newer truck?
Chuck
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | The path of least resistance (and likely costs) is the 3:55 gear installation. It's been a while since I purchased a set but the hears and bearing kit (highly recommended) was about $800-$900.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | In addition to SWEET's recommendation, you should consider getting an Installation Kit: 1941-1950 or 1951-1954. | | | | | Joined: Feb 2000 Posts: 5,203 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,203 | No! Nothing else will fit in the original location. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | A 3.90 from a 55 and later will fit the banjo housing, but then you will have to go to an open drive shaft which means a different transmission. A 235 will easily handle 3.55 gears. | | | | | Joined: Apr 2010 Posts: 123 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 123 | Thanks for the excellent info. You have answered my questions.
That will be the last thing I will worry about when the truck is finished. I will search around for the gears from the '48 I stripped and junked years ago. I drove it, but cant remember the feel it had. It was probably the same as my '50. If I still have it, I can get the numbers off it. That '48 was a real rust bucket, but the engine and drive train felt great.
Chuck
| | | | | Joined: Apr 2010 Posts: 123 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 123 | I found the gears. 37 teeth making it a 4.11:1 Oh well. Better start saving my money. Thanks for the link tclederman. http://chevy.oldcarmanualproject.com/chevyresto/51126.htm
Chuck
