5 members (Gdads51, Waveski, RdsLessTaken, frogfarmer, 1 invisible), 88 guests, and 4 robots.
Topics128,205
Posts1,057,425
Members48,471
Junior Member
Junior Member
1 Offline
Were could I find a twin 2 BRL manifold fore my 1951 chevrolet 3100.
MY NAME IS MARIO RUBALCAVA MARTINEZ I AM 17 YEARS OLD AND I AM A PROWDE OWNER OF 1951 CHEVROLET 3100 1/2
As far as I know there are know two barrel manifolds available for the 235. You can get a four barrel manifold for these engines. Also, they make a manifold for two and three single barrel carbs. smile
For your info I tried a old 2 / 1 barrell intake on my 235 and had altogether way to much trouble with it, so I went w/ a Clfford water heated intake , works great . I used a edlbrock 500 cfm, the 2 best things I 've bought for it so far. You can put 2 or 4 barrel on them, and they have intakes for 2 carbs. Go to ;www.cliffordperformance.com
Don
You can get a twin one bbl manifold and 2 bbl adapters. It doesn't look the best, we did it on my friend's truck. One project in the works is to machine our own adapters, cut the mounts off the manifold, and weld the new adapters on.
Fred
52 3600
69 C-10
I have a two barrel to one barrel adapter, do they actually make an improvement since they're flowing into a single bore opening? I often wondered about modifying a regular manifold to accept a two barrel. Would you still need an insulator like the one barrel had? smile
Just curious, I really don't care, but what the heck is this thread doing in the RUST forum???? grin
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
Quote
Originally posted by Whitelightning:
I have a two barrel to one barrel adapter, do they actually make an improvement since they're flowing into a single bore opening? smile
Yes, your flow will be somewhat restricted, but that does help keep the torque up. What we are looking at is to cut the current plates off at the tube on the manifold and make 2 bbl plates with larger openings and weld them on. Currently he does not have insulators under his Webers.
Fred
52 3600
69 C-10
