0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 91 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 91 | After doing a ring and pinion change on my 48 1 ton GMC I am now looking at the speedometer which never has worked right since I purchased the truck. I have contacted a couple of shops inquiring about re building my existing speedo, have a general estimate back from onefor $165-225. My question is to the folks that have purchased re-pop speedometers, (which I can get for $140 and up,) where did you get it ,cost and are you happy with it? Are any reproductions made here in the USA or all from...C
| | | | | Joined: Jun 2012 Posts: 91 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 91 | | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | What do you mean by your current speedo has never worked right? What is it doing or not doing? Do you have a good speedo cable installed?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Dolphin, Auto Meter, Classic, all work good and you calibrate most by simply driving a measured distance and pushing a button. I haven't bought a GPS speedometer yet but did make a cradle for my Garmin in my old 37 Buick. I like the fact that it's always correct regardless of gears or tires, shows the posted speed limit and as a last resort can even be used as a GPS.
Evan
| | | | | Joined: Jun 2012 Posts: 91 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 91 | Yes I have a good cable, when I reverse the dial turns counter clockwise to about 80, going forward it will go up to about 15mph and then very slowly move up to about 40-45. I know it probably needs to be cleaned,some parts replaced, ect,ect. What I was hoping for was info on speedo shops for repair or experiences with reproductions such as are they worth the asking price, do they last ect. | | |
