1 members (baldeagle), 89 guests, and 4 robots.
Topics128,037
Posts1,055,466
Members48,424
#1091758 03/16/2015 5:39 PM
Hello,
Had my flywheel resurfaced today and the outer edge was 7000 of an inch deeper than the main surface. Any idea why?
I believe the engine came out of a 55 truck with low miles so it may be original.
Chris
51chris #1091871 03/17/2015 4:21 AM
Chris, not sure if this will answer your question but I just finished cleaning and buffing up my flywheel which is going behind a 261. I've see lots of flywheels where the area that the clutch goes against is "raised" a little and looks like a "pad". I don't know the reason but I've seen many this way.
...and it could be that the "pad" is how much you can turn one before it gets to thin or maybe its thicker to act as a "heat sink" to keep it from getting to hot and warping. Just my perspective, no documentation to back it up.
