4 members (dt235sd, 52Carl, Hotrod Lincoln, moparguy), 370 guests, and 3 robots.
Topics128,159
Posts1,057,033
Members48,460
I can not find diagrams or replacement parts to my 1955 1st series 3100. The seat will not adjust. I want to remove it and inspect the under side. What should I be aware of? Is there a web site for replacement parts?
Not a lot of moving pieces under the 51-55 1st seat? Usually they just need cleaning or new grease. I am not aware of any vendor selling parts for rebuilding them. Clean and lube them, make sure the small adjustment lock spring is intact and the rod is there that connects the two tracks for release. There is a grommet that holds the rod to the seat frame which is available in reproduction.
https://www.flickr.com/photos/advance-design_parts_co/12315510004/in/set-72157640522200463
Moderated by  ndkid275, Phak1
