0 members (),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | What happens when you put them loose on the frame then bolt them to the bumper? | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Brackets bent? Frame bent? Frame horns intact? Fenders and valance free from damage? | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Mine looked just like yours, the bumper was pitched down. Never did find any combination to make the bumper level. Didn't find anything bent. My valence is one of the fiberglass reproductions and I ended up cutting the hole higher into the valence to get the bumper level. After adding the rubber cover it's not very noticeable. I doubt anyone else notices it much, but then my truck is more "repaired" than "restored".
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Was curious about this fit and had time today to bolt up the brackets on my '46 project. The fenders and brackets are not tightened down to final so this may be meaningless. But, the the brackets appear to not droop as the pictures posted above show. I did notice the brackets come close to touching the valance ports. The valance is a reproduction part I bought off ebay listing a few years ago. The brackets are reproduction parts too. I'm a long way from being at the point of final on this. Parts are being assembled to check fit before body and paint work. | | | | | Joined: Dec 2012 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 43 | Nothing is bent as far as we know it. Frame, frame horns, brackets are all original. The valence is a fiberglass reproduction. Thanks for all the input.
| | | | | Joined: Oct 2008 Posts: 309 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 309 | Hi, I also have a '46 1/2 ton. Got hit-and-run about 4 months ago which slightly bent my bumper and cracked the chrome off it. Fortunately we caught the guy and my bumper just got finished today. Anyway, I took some photos of my front bumper brackets for you. These are original equipment and the fenders and valance are steel - original to the truck. Hope these pics help you out. I took 5 pictures, wide and both brackets from the front and above. Let me know if you can't see them all. http://s456.photobucket.com/user/blastenpene/media/46%20Chev/IMG_0001.jpg.html?sort=3&o=4Good luck, David | | | | | Joined: Nov 2014 Posts: 623 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 623 | I may be wrong, but it sure looks to me like the bracket in your first pic was heated (maybe bent, shaped?), from what I'm seeing at 3 or 4 spots that are grey colored, like they've had a torch on them for heat. (The place where the number is stamped, then at the bend coming off the bolt on spot, then to the right on the other piece.) Looking at the top of that grey spot to the right, it looks like the top edge has been either beat or maybe welded and reformed, or something. Maybe not, but when steel is heated it gets that grey tint at the heat affected zone. Also, that hole on the inner bracket flat stock doesn't have the same slotted hole as the outer (and David's), and the steel flat stock there looks newer, and drilled. And yours doesn't look shaped quite like David's. Maybe a PO had a bumper bender and had to do some re-fab work to fixt it. But that's just what I see, and I'm no expert at those year of trucks. (Except my grandfather had one about 50 years ago.
"When I rest, I rust" 1951 3100 5 window w/ '56 235
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Mine matches the pics David posted. I too wondered about the bracket color differences referenced by Showme and as shown in the first post. | | | | | Joined: Dec 2012 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 43 | Thanks for the pictures. They are very helpful. It looks like the are very close to the top of the holes in the valence. A question I have, do they mount with the chamfered edge on the frame end of the bracket up?
Yes one of my brackets has been worked on. Half of the bracket on one side has been fabricated to (supposedly) match the other side. Looks like we have some work to do on them to get them shaped properly.
Thank You
| | | | | Joined: Oct 2008 Posts: 309 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 309 | | | | | | Joined: Dec 2012 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 43 | Thank You for the picture. I think the issue I am having is due to a difference between the original steel lower valance and the replacement fiberglass version. Based on some measurements I took, the hole in the fiberglass version is too low by about 1-1/4". I are going to solve this by modifying the brackets to lower them by ~1-1/2"
Thank You for your input, | | |
