1 members (baldeagle),
46
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | Hello, Had my flywheel resurfaced today and the outer edge was 7000 of an inch deeper than the main surface. Any idea why? I believe the engine came out of a 55 truck with low miles so it may be original. Thanks Chris | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Chris, not sure if this will answer your question but I just finished cleaning and buffing up my flywheel which is going behind a 261. I've see lots of flywheels where the area that the clutch goes against is "raised" a little and looks like a "pad". I don't know the reason but I've seen many this way.
...and it could be that the "pad" is how much you can turn one before it gets to thin or maybe its thicker to act as a "heat sink" to keep it from getting to hot and warping. Just my perspective, no documentation to back it up. | | |
