1 members (Hotrod Lincoln),
116
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 30 New Guy | | New Guy Joined: May 2012 Posts: 30 | I have 2 different timing gear covers one has a oiler restricted line and is a Chevy I think and the other is cut off tube and possibly a gm. Which would be better to use? | | | | | Joined: May 2012 Posts: 30 New Guy | | New Guy Joined: May 2012 Posts: 30 | | | | | | Joined: Feb 2004 Posts: 29,817 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,817 | Timing gear covers (the sheet metal ones) don't have oilers. Are you talking about the plate between the cam gears and the block? There are a few different separator plates, depending on the type of front motor mount you need to use. Jerry
| | | | | Joined: May 2012 Posts: 30 New Guy | | New Guy Joined: May 2012 Posts: 30 | I'm talking about the one between the block and gears. They look exactly the same motor mount and all. The only difference I see is the oiler tube, maybe someone cut the end off the one that had the end open.. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | That is the front engine mount plate. The oiler should not be cut off or even opened wide.
Drew
