5 members (55shaker, Jay R, Oswald, Joe H, Ponchogl), 85 guests, and 3 robots.
Topics128,268
Posts1,058,391
Members48,485
#109169 03/24/2004 3:57 AM
Any experience/suggestions on what to use to finish my running boards? (49 1/2 ton) Even with step plates and polyurethane auto paint, they will get skuffed and scratched. I was thinking about trying a textured epoxy finish. Ideas are welcome.
#109170 03/24/2004 4:18 AM
powder coating? imron?
#109171 03/24/2004 4:41 AM
grin
How about the stuff they spray in pickup beds - spray on pick up bed liner? They have it in colors now. I've seen it used on the backside of bumpers to finish off the look of a bumper on cars or trucks that don't have gravel pans between the bumpers and the body. It looks pretty good and it is tough stuff!
#109172 03/24/2004 6:02 AM
I had mine powder coated. But it all depends
on how your going to use it. If your just going
to use it occasionally I wouldn't worry to much
about what finish you put on them. Just put on
whatever YOU like. But, if it's going to be
a daily driver you had better go with the
rough tough finish.
#109173 03/26/2004 10:39 AM
I used Herculiner bed liner on my runningboards, and on the bed strips, since i had a set of new mild steel ones i didn't want to waste. Used black color....Looks good, wears great, no slipping! $90 for the dit with roller, brusch, etc.
#109174 04/06/2004 4:14 AM
I used bed liner on the boards of my 40 chev sedan. the origional finish was a rubber type of material that looked like it was moulded on to the boards. The bed liner looks great and lets the ribs of the board show. This was done about four years and 50 thousand miles ago. Still looks great and is easy to look after. The guy that did the spraying made the texture so it ended up with a smooth finish compared to some boxes I have seen. Check with a local business and ask if they can "reduce the lumpiness of the material". You will be pleasantly surprised with what can be done. My cost was $100 Canadian.
#109175 04/06/2004 4:37 AM
"Hammered" finish paint..
Another quality post.
Real Trucks Rattle
#109176 04/06/2004 5:54 AM
Anonymous
Unregistered
Anonymous
Unregistered
I have used polyurethane and watched the scratches multiply. I did a set with Imron about 15 years ago with a dark metalic gun metal gray. Turned out great and didn't scratch noticeably.
