7 members (Peggy M, joe apple, WICruiser, baldeagle, Bill Hanlon, dt235sd, Stovebolt48),
118
Mod | | | Forums66 Topics128,038 Posts1,055,471 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 44 | anyone had any luck with these regulators. ive heard they don't last | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | There are posts saying they have stripped the first time after installation. I would suggest posting an ad for one in Swap Meet. As long as the original rotational splines are good the crank driven mechanism is a pretty easy rebuild. The only real weak point on the original is usually a PO stripped out the threads under the window crank. | | |
