Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Peggy M, Wayne67vert), 159 guests, and 5 robots.
Topics128,281
Posts1,058,471
Members48,490
#10914 11/24/2004 10:15 PM
Custom Title
Custom Title
I've got my 235 torn down and found that it has been bored .060 over at some point in it's lifetime. The bores aren't terrible and could probably be rehoned, but is it possible to bore it larger, to say .080 or .125? How big can you go with one of these. It's a '55 block.
Also, how much can be taken off the crank? Right now the mains are at .020 and the rods at .040. Is it time to find a new crank?
49 Chevy 3600
65 Chevy K10
66 International 1300 dually 4x4
46 Ford 1/2 ton
76 Tucker Sno-Cat 1642
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
#10915 11/25/2004 3:06 AM
Most suppliers carry overbore pistons to .08 over--I wudn't want more than that myself but talk to ur machinist.
Buzz'n Half Dozen
#10916 11/25/2004 3:23 AM
My 54 235 went .080 over no sweat. First issue should be, what sizes are currently available, ie. piston, rings and bearings?
Re. the bore, you can have the cylinders sonic tested.
1946 1/2-Ton Chevy
#10917 11/25/2004 11:40 AM
You have to see what they make for over size bearings. How bad is it? If a bearing is gone it's probably time to replace.
#10918 11/26/2004 8:36 AM
Patrick's lists pistons for +.080.
Be sure your machinist sounds out the cylinder wall thickness to be sure you will have enough wall left before you bore it! Rust pockets on the water side of the cylinder can cause thin spots and a bad day!
Sleeves can be an option and send you back to standard bore size!
47 Fleetmaster, Hotrod 6, 5 Speed
50 Sedan Delivery, 327, 5 Speed
