5 members (Rusted Nut, Southerntruck, MickeyP, mick53, Dennys28), 102 guests, and 3 robots.
Topics128,043
Posts1,055,611
#1091396 03/14/2015 8:57 PM
I bought a power steering kit. The bracket for the pump bolts to my small block, but the pump hits the engine and the frame. Not much play. Do I need to go to long water pump and new brackets or?
Sir Searchalot
Sir Searchalot
Any pics?, where did you get kit? Does the pulley line up? More info. Long water pump may change other pulley alignments. Donor parts or a universal kit? Some Chevy motors (like yours) have the Alt on driver side, same side as pump. I don't like that idea. You may find that moving alt to pass side will give you options for pump bracket/mounting modifications. Just a thought. Of course, if you get the proper donor brackets for the year motor you have, they should work unless the motor never had PS.
I am working with POL, to try and figure out what gives. I will try and get some pics up. Never thought of moving the alternator, but I want to put the ac pump on that side.Thank you bartamos for the help.
Brett
Sir Searchalot
Sir Searchalot
POL website says it works for long and short water pump. Started to check out with 1965 standard pump and it did not ask?? So assume it's "universal"?
