2 members (dt235sd, Sjm),
99
Mod | | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 1,135 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,135 | I have T&C horns and a bracket for the '46 Chevy 1/2 ton project. I am uncertain it is the correct bracket. I need a photo of the installed horns, bracket and mounted assembly. Please. Thank you. | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | I don't know if it's germane to the '46 but here's the bracket on my '38. Photo 1 Photo 2 Pre restoration.
| | | | | Joined: Feb 2008 Posts: 1,135 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,135 | Thank you, Tiny.
The bracket attached to these horns is different. It appears to bolt to the firewall. The bracket is trapisoidal shaped with four mounting holes, one in each corner. Only 3 of the holes seem to match corresponding holes in the firewall. I'll get a pic and post a link. I don't know if it's correct. | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Tiny: That might be the best looking horn bracket ever. Thanks....might not be the "correct" thing for my truck, but it might be the next thing for my truck.
Steve H
| | | | | Joined: Feb 2008 Posts: 1,135 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,135 | Here's a link to a photo. T&C Horns and bracket In looking at the Accessories Book the bracket does not match, but I also understand that reference should not be used as "proof". Apparently, the photos were not always changed to reflect year to year changes. | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | I have the same bracket as Tiny's 38 on my 39. In 1939 the city/country horns were the same for passenger cars and trucks except the truck had a bolt on extension on one side. In 1940 they were called town/country. I have a switch on the dash that says city/country to go from one to the other. I always leave it on the country horns. They do sound sweet.
Rick
1939 Chevrolet Stake Truck
