1 members (baldeagle), 40 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#1091119 03/13/2015 3:10 AM
1 Offline
After doing a ring and pinion change on my 48 1 ton GMC I am now looking at the speedometer which never has worked right since I purchased the truck. I have contacted a couple of shops inquiring about re building my existing speedo, have a general estimate back from onefor $165-225. My question is to the folks that have purchased re-pop speedometers, (which I can get for $140 and up,) where did you get it ,cost and are you happy with it? Are any reproductions made here in the USA or all from...C
1 Offline
Nobody?
What do you mean by your current speedo has never worked right? What is it doing or not doing? Do you have a good speedo cable installed?
Craig
Dolphin, Auto Meter, Classic, all work good and you calibrate most by simply driving a measured distance and pushing a button. I haven't bought a GPS speedometer yet but did make a cradle for my Garmin in my old 37 Buick. I like the fact that it's always correct regardless of gears or tires, shows the posted speed limit and as a last resort can even be used as a GPS.
Evan
1 Offline
Yes I have a good cable, when I reverse the dial turns counter clockwise to about 80, going forward it will go up to about 15mph and then very slowly move up to about 40-45. I know it probably needs to be cleaned,some parts replaced, ect,ect. What I was hoping for was info on speedo shops for repair or experiences with reproductions such as are they worth the asking price, do they last ect.
