1 members (baldeagle),
61
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I have a Fulton visor with the center support (1953 3100) I'm trying to bolt the 2 center sections together, the top and bottom parts. It holds the 2 center supports in place, then the stainless steel strip hides the fasteners. My question is this, what kind of fasteners did you use, how long of a fastener and what thickness? What kind of nut? a sheet metal type or a regular nut. I like pics. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I have some on my other computer. If no one posts pics I'll send you what I have tomorrow after I fire my desktop up.
| | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | Hi again I too have some pics buried deep in my computer if needed. I used the original ones that came with the Fulton on my truck. They are simple round head stovebolts with square nuts attached on the other side. The heads face down so they are visible from below from the driver's side. They are nothing fancy. If you want to pics of mine just let me know. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Thanks Peter, that helps. My visor is missing a few things, mostly there but no bolts and one bracket isn't there either. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I sent you what pics I have. I frankly don't remember how the two center halves fasten together. If the pics I sent don't show what you need I'll go out to the garage and take a look. I believe they may be what's called a Binding Post similar to what holds the end brackets and center support clamps together.
