0 members (),
149
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 26 | There I was faced with a flange gasket leak on my 235 and the thoughts of a broken stud because the nuts haven't been removed for over 30 years. Over the course of the last 2 months I've soaked the nuts with PB blaster and finally got the nerve to put a socket to it. I didn't want to get carried away so I used a 3/8 ratchet.The rear nut came off no problem, but the front was locked-up. Ok heat, PB, socket, no go. Heat, wax, cool down, socket, no go. Three days of this sequence/combination I heated that nut red put an ice cube on the stud and YES that nut submitted. Today was a good day and the moral of this story is patience is a virtue and every problem has a solution. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Congratulations
Let us know if/when you get it together with no leak.
| | | | | Joined: Sep 2013 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 26 | Went down to o'reillys and dug through their stock until I found a suitable donut, anti-seized the studs, new nuts, snugged it up and oh-yeah what beautiful music! | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | | | | | | Joined: Sep 2013 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 26 | Thanks for the tip GWWIRTH I'll run that by the mechanic at work tomarrow. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You were very smart to take your time & use caution. Most guys just get on them till they break off. Usually you heat them cherry red & as soon as they cool to not glowing turn them till they come loose. Then let it cool & spray it good with the blaster & screw it off. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
