0 members (), 120 guests, and 3 robots.
Topics128,093
Posts1,056,474
Members48,444
#1090387 03/09/2015 2:49 AM
There I was faced with a flange gasket leak on my 235 and the thoughts of a broken stud because the nuts haven't been removed for over 30 years. Over the course of the last 2 months I've soaked the nuts with PB blaster and finally got the nerve to put a socket to it. I didn't want to get carried away so I used a 3/8 ratchet.The rear nut came off no problem, but the front was locked-up. Ok heat, PB, socket, no go. Heat, wax, cool down, socket, no go. Three days of this sequence/combination I heated that nut red put an ice cube on the stud and YES that nut submitted. Today was a good day and the moral of this story is patience is a virtue and every problem has a solution.
Congratulations
Let us know if/when you get it together with no leak.
Went down to o'reillys and dug through their stock until I found a suitable donut, anti-seized the studs, new nuts, snugged it up and oh-yeah what beautiful music!
Use brass nuts
Thanks for the tip GWWIRTH I'll run that by the mechanic at work tomarrow.
Riding in the Passing Lane
You were very smart to take your time & use caution. Most guys just get on them till they break off. Usually you heat them cherry red & as soon as they cool to not glowing turn them till they come loose. Then let it cool & spray it good with the blaster & screw it off.
1972 Chevy c10 Cheyenne Super
