Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (Jon G, MikeStone1953, Woodcmiami, 3 invisible), 165 guests, and 3 robots.
Topics128,279
Posts1,058,582
Members48,492
Just tore down this engine and found its pretty worn. I need to source oversize pistons, rings, cam, lifters, etc. A total rebuild. Can anyone direct me to a supplier?
Riding in the Passing Lane
Kanter Auto products
1972 Chevy c10 Cheyenne Super
You might try Butler Performance, http://jbp-pontiac.com/
Kaufman racing, http://www.krepower.com/
Nunzi Pontiac, http://www.nunzipontiac.com/
or here for all the Pontiac information you would ever want,
http://forums.maxperformanceinc.com/forums/
Joe
The 1958 336 engine was a reduced-bore version of the 370 automotive engine with a 3 7/8" bore. The 370 has a 4 1/16" bore. That would be a 3/16" overbore, or 0.1875" If pistons are hard to find it might be possible to bore it to accept the bigger pistons, assuming the same 270 block casting was used. That's a very large overbore, but it might work if the same casting was used for the smaller engine.
