1 members (Samantha),
80
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,637 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 290 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 290 | I have a 1948 1 ton GMC dually which is very slow going down the road. It looks like an eaton rearend, What years can I go to to get a high geared pumpkin to swap out with. Thanks | | | | | Joined: Jul 2007 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 59 | Slick69, I've converted two GMC 1-tons from the 5.14 to 4.10. I refer you to the following site for a thorough "how to": oldGMCtrucks.com, on the homepage select "Technical Stuff", then select "3/4 Ton Rear End Swap" located in the middle column near the top. Pretty simple job with a 20% gain. | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Simple, if you can find the rear end. Look for a 68-72 Chevy 3/4 ton with factory 350/auto. And there behind you will find a 4.10 rear end. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Still worth checking the ratio prior to purchase, it may or may not still have 4.10 gears. | | | | | Joined: Oct 2014 Posts: 9 New Guy | | New Guy Joined: Oct 2014 Posts: 9 | I have a 48 3800 and I found a 4.10 ring and pinion from a Suburban but it does not have the entire carrier assembly. Can anyone tell me if on of these eaton HO52 gear sets will fit (bolt into) into my factory carrier or do I need an entire 67-72 carrier? Thank you | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | I think the issue is the ratio. I believe 4.56 and 5.13 used a different carrier than the 4.10 and higher. Of course, the earlier ones only had the lower ratios. Since the pinion on the low geared ones is smaller, either the ring gear must be thicker or the carrier mounting flange must be closer to the pinion. A visual check should tell you if you have everything apart and can compare. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Oct 2014 Posts: 9 New Guy | | New Guy Joined: Oct 2014 Posts: 9 | 1Ton_tommy Thank you, much appreciated | | | | | Joined: Aug 2008 Posts: 290 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 290 | Thanks guys. That website helped. Where can one check for the #'s that are stamped on the rear end pumpkin? I have a couple here but without pulling them not sure what the gear ratio is. HG816 & U303 are the #'s of each pumpkin. Thanks again for all the help
| | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | Slick, Be sure to check *this* site's Tech Tips, too. We have one for this that's pretty comprehensive and has a lot of photos with it. If the link doesn't work, let us know -- we've been having some issues. It really is a simple upgrade.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Aug 2008 Posts: 290 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 290 | | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Many rear ends have the ring and pinion ratio stamped on the end of the pinion shaft, under the U joint, so that can be checked without taking the whole works apart, just to make sure it hasn't been changed to something else.
| | | | | Joined: Jun 2012 Posts: 91 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 91 | Did the pumpkin swap yesterday. Using the tech tip provided here helped alot. It went very well, did it in about 6 hours by myself, actual hands on time was probably 4 hrs, wife made a late breakfast about midway through, played with the grandkids a bit and went back at it. I made a jig for my floor jack to remove original and replace with the 4:10. All in all it went very well, noticeable difference on the road. Maybe I will be able to keep up with traffic now. Thanks to Stovebolt for the tech tip! | | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | Glad to hear it, Plowboy! Thanks for the feedback! And congrats on the successful upgrade!
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 | Did the pumpkin swap yesterday. Using the tech tip provided here helped alot. It went very well, did it in about 6 hours by myself, actual hands on time was probably 4 hrs, wife made a late breakfast about midway through, played with the grandkids a bit and went back at it. I made a jig for my floor jack to remove original and replace with the 4:10. All in all it went very well, noticeable difference on the road. Maybe I will be able to keep up with traffic now. Thanks to Stovebolt for the tech tip! Do you mind me asking what the pumpkin ended up costing you? Trying to figure out what I want to do. Thanks, Larry W.
1953 3800 Dually Flatbed
| | | | | Joined: Jun 2012 Posts: 91 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 91 | Paid $180 for a complete rear axle assembly out of a 68 Chevy. I have the removed 5:14 installed in the donor axle and listed on craigs list. I also paid $41 and some change for new gaskets, gear oil, and gasket sealer. So that said got the job done for just under$225, depending on wheather or not I can sell the donor...total cost? Very happy with the results, did think about going with a newer GM 14 bolt but looked at both options, this was much easyer. However the 14 bolt does give more options for gear ratio and future brakes. My Huck brakes are very good, hopefully last as long as I do. | | | | | Joined: Feb 2013 Posts: 613 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 613 | Lucky find! Still on the elusive search for that rare piece. Have fun in the fast lane! | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Very happy with the results, did think about going with a newer GM 14 bolt but looked at both options, this was much easier. However the 14 bolt does give more options for gear ratio and future brakes. My Huck brakes are very good, hopefully last as long as I do. That's a very good summary of the two major rear axle swap/gear options. I like the 14 bolt swap because it gives easy access to brake parts and numerous (better) axle gear options. That said I have been looking at another 1 ton and if I buy and drive it home the HO72 pumpkin swap in the driveway would be a real easy thing to do, make a long drive a little more fun. Both good options, one or the other ought to fit most situations. Grigg | | | | | Joined: Jun 2012 Posts: 91 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 91 | Also with more options for gear ratio's on the 14 bolt one needs to keep in mind the power source, my truck having the original stock 228 with all of it's 88 HP I'm concerned about being under-powered if I went with higher (faster) gearing than 4:10
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Yes, good point on the gears and which engine you have.
I drove my 1 ton with 4.56 gears and a 55 model 235 a lot. I felt it was geared just right for around town and practical use hauling firewood and whatever else you can pile in a 9' bed. Though for longer trips I am pretty sure 4.11 would have been great, and I may have gotten by with 3.73 and my limited power. But back at home and normal use I think 3.73 would have been to much gear for the little 235.
All that to say 4.11 or 4.10 is probably about perfect for these old trucks without changing much else.
Grigg | | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | We just updated the Tech Tip with some new info regarding donor axles. One of the big news flashes out of the update concerns brakes -- One of the experts (Barry) tells us the brakes are a bolt-on interchange between ALL HO52/72 axles ... (SRW to SRW, DRW to DRW, etc). Would someone like to confirm this?
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Nov 2012 Posts: 442 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 442 | John. I have that rear sitting on the trailer we yanked your/our center section from. ODSS summer getaway project ? The shop is ready ! I'm game. 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 |
| | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 | Yes please confirm. Does that mean if I get the diff out of a 67-72 c20 with an Eaton (HO53) that I can also swap all of the brake hardware over to it too? I.E. backing plates and all the hardware attached to them and the drums?
AND
Let's say I wanted to ditch the duals on my 3800. Can I use the HO52 parts (axle shafts needed?)and then go to singles front and back? Ditch the front spacers or replace the hubs?
My mind is churning with options.
I was considering the 14 bolt for newer brakes, but 67-72 brakes are good enough for me.
Larry W.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | There has been discussion on other threads about the 14 bolt axle that hubs and brakes (much more modern) are more or less interchangeable with the old Eaton axles as well. I do not recall the details or troubles but I do remember it being more or less possible with not a lot of effort.
So if you want even newer brakes- then those on a 14 bolt are sure something to look into. | | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 | Good to know too. Thanks,
I was reading "that" thread just now and unless I read wrong, there is a wheel bearing size issue that requires machine work. Now that thread is very confusing because of all of the tangents it went off on, so I could have gotten it wrong.
If it turns out that the HO53 brakes will work on the HO72, I'm in. Especially if there is a way to do the duals from one.
Larry W.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Right, these brake and axle component swapping threads tend go get off on tangents and or not wrapped up. I am guilty of that myself, start on a project and something more important comes up. Then a year or three later I forget where I was and have to start over again.
It takes a lot of work to test, document, and report back on these swapping ideas.
Grigg | | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 | [i] Right, these brake and axle component swapping threads tend go get off on tangents and or not wrapped up. I am guilty of that myself, start on a project and something more important comes up. Then a year or three later I forget where I was and have to start over again.
Grigg Grigg and Shade Tree. Understood. Just to clarify, I meant no offense to anyone and the tips and research are VERY appreciated. I have caused a few tangents myself. I just get confused easily. People will always ask about their specific situation as will I. Like this... LOL. If I can find a way to swap my 1953 3800's HO72 5.14's for 4.10's from an HO53 AND put newer brakes on the HO72 while keeping my duals AND put disc brakes on the stock front axle AND have the front and rear bolt patterns match AND fit a modern 1 piece wheel... I'll be happy. LOL LOL Sounds ridiculous, but that is the real situation. My head hurts. Larry W.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Sounds like a good plan and all possible. The wheels I'd look for are 19.5", and run 8R19.5 tires.
Speaking of tangents...
Grigg | | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 | Thanks Grigg.
Standard 8 0n 6.5 pattern I assume? I can't measure, I wont have the truck until Sunday am.
I haven't looked at it all yet, but you have some nice tangents there!
Larry W.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Correct, found on GM and Ford step vans, 4x4 trucks, and any other 3/4 or 1 ton you're lucky enough to find them on. Certainly not found on all of those possibilities though, also by chance. | | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 | Cool,
Not sure I would have thought of the step vans, but they do have duals I guess. I think I saw some 19.5's on CL recently. I'll have to look again.
Thanks Again,
Larry W.
| | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 | The wheels I'd look for are 19.5", and run 8R19.5 tires.
Grigg What about 16's Grigg? Too small? Look funny? Clear the brakes, with or without disc brakes? I think it has 18's now and they pretty much fill the front fenders from what I can see in pictures of it. Larry W.
| | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 | Not sure of the lug pattern, but I also found this set of 6 wheels and tires. Looks like they are 8-17.5's. Not sure how common of a size that is but they seem pretty cheap for the condition. Larry W. Forgot the link. https://jacksonville.craigslist.org/pts/4893368563.html
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If dual wheel and you had 18" wheels you may not fit 16" wheels over the brake drums. Have to try and see
17.5" is also tubeless and desirable because of that but a little small I think.
In my opinion 19.5" wheels and 8R19.5 tires being 32-33" tall and still quite skinny just look appropriate on an old 1 ton. Nothing wrong with the original wheels and tires but if you do want tubeless; 19.5" look "just right"... To me
| | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 | If dual wheel and you had 18" wheels you may not fit 16" wheels over the brake drums. Have to try and see
In my opinion 19.5" wheels and 8R19.5 tires being 32-33" tall and still quite skinny just look appropriate on an old 1 ton. Nothing wrong with the original wheels and tires but if you do want tubeless; 19.5" look "just right"... To me Ok, Thanks. Thought you might have tried them before. Been doing some looking and the P30 19.5's I'm finding have platinum rims or some such thing. LOL If the rims on mine look OK, I may just stick with those, at least for the near future. I don't have a grand plus to drop on used wheels and tires right now. Larry W.
