2 members (Hush, Forty9), 90 guests, and 1 robot.
Topics128,050
Posts1,055,643
#1079533 01/16/2015 1:02 PM
I have a 1948 1 ton GMC dually which is very slow going down the road. It looks like an eaton rearend, What years can I go to to get a high geared pumpkin to swap out with. Thanks
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
Slick69 #1079535 01/16/2015 1:26 PM
Slick69, I've converted two GMC 1-tons from the 5.14 to 4.10. I refer you to the following site for a thorough "how to": oldGMCtrucks.com, on the homepage select "Technical Stuff", then select "3/4 Ton Rear End Swap" located in the middle column near the top. Pretty simple job with a 20% gain.
Joe
1947 Second Series GMC 1-Ton Longbed
More pix in the Bolt Bucket
Slick69 #1079611 01/16/2015 8:03 PM
Simple, if you can find the rear end. Look for a 68-72 Chevy 3/4 ton with factory 350/auto. And there behind you will find a 4.10 rear end.
Slick69 #1079633 01/16/2015 9:16 PM
Still worth checking the ratio prior to purchase, it may or may not still have 4.10 gears.
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #1082834 01/31/2015 11:20 PM
V
V Offline
I have a 48 3800 and I found a 4.10 ring and pinion from a Suburban but it does not have the entire carrier assembly. Can anyone tell me if on of these eaton HO52 gear sets will fit (bolt into) into my factory carrier or do I need an entire 67-72 carrier?
Thank you
Slick69 #1082943 02/01/2015 7:25 AM
1 Offline
I think the issue is the ratio. I believe 4.56 and 5.13 used a different carrier than the 4.10 and higher. Of course, the earlier ones only had the lower ratios. Since the pinion on the low geared ones is smaller, either the ring gear must be thicker or the carrier mounting flange must be closer to the pinion. A visual check should tell you if you have everything apart and can compare.
1951 3800 1-ton
In the DITY Gallery
1Ton_tommy #1082952 02/01/2015 12:25 PM
V
V Offline
1Ton_tommy
Thank you, much appreciated
Slick69 #1084494 02/09/2015 1:09 AM
Thanks guys. That website helped. Where can one check for the #'s that are stamped on the rear end pumpkin? I have a couple here but without pulling them not sure what the gear ratio is. HG816 & U303 are the #'s of each pumpkin. Thanks again for all the help
"IT IS WHAT IT IS"
In the DITY Gallery
1953 Chevy 1-Ton
Slick69 #1085057 02/11/2015 6:30 PM
62401
Slick,
Be sure to check *this* site's Tech Tips, too. We have one for this that's pretty comprehensive and has a lot of photos with it. If the link doesn't work, let us know -- we've been having some issues.
It really is a simple upgrade.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Slick69 #1086013 02/16/2015 6:43 PM
Thanks, John
"IT IS WHAT IT IS"
In the DITY Gallery
1953 Chevy 1-Ton
Slick69 #1087930 02/25/2015 9:27 PM
Crusing in the Passing Lane
Many rear ends have the ring and pinion ratio stamped on the end of the pinion shaft, under the U joint, so that can be checked without taking the whole works apart, just to make sure it hasn't been changed to something else.
Slick69 #1088933 03/02/2015 4:02 AM
1 Offline
Did the pumpkin swap yesterday. Using the tech tip provided here helped alot. It went very well, did it in about 6 hours by myself, actual hands on time was probably 4 hrs, wife made a late breakfast about midway through, played with the grandkids a bit and went back at it. I made a jig for my floor jack to remove original and replace with the 4:10. All in all it went very well, noticeable difference on the road. Maybe I will be able to keep up with traffic now. Thanks to Stovebolt for the tech tip!
Slick69 #1088976 03/02/2015 11:47 AM
62401
Glad to hear it, Plowboy! Thanks for the feedback! And congrats on the successful upgrade!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
1Plowboy #1089010 03/02/2015 4:20 PM
Do you mind me asking what the pumpkin ended up costing you?
Trying to figure out what I want to do.
Larry W.
1953 3800 Dually Flatbed
Mrf1002u #1089023 03/02/2015 5:14 PM
1 Offline
Paid $180 for a complete rear axle assembly out of a 68 Chevy. I have the removed 5:14 installed in the donor axle and listed on craigs list. I also paid $41 and some change for new gaskets, gear oil, and gasket sealer. So that said got the job done for just under$225, depending on wheather or not I can sell the donor...total cost? Very happy with the results, did think about going with a newer GM 14 bolt but looked at both options, this was much easyer. However the 14 bolt does give more options for gear ratio and future brakes. My Huck brakes are very good, hopefully last as long as I do.
Slick69 #1089045 03/02/2015 7:35 PM
Lucky find! Still on the elusive search for that rare piece. Have fun in the fast lane!
~ Jim Schmidt, Bucks County, PA
1953 Chevrolet 3804 1-ton
In the DITY Gallery
1Plowboy #1089048 03/02/2015 7:41 PM
Very happy with the results, did think about going with a newer GM 14 bolt but looked at both options, this was much easier. However the 14 bolt does give more options for gear ratio and future brakes. My Huck brakes are very good, hopefully last as long as I do.
That's a very good summary of the two major rear axle swap/gear options.
I like the 14 bolt swap because it gives easy access to brake parts and numerous (better) axle gear options.
That said I have been looking at another 1 ton and if I buy and drive it home the HO72 pumpkin swap in the driveway would be a real easy thing to do, make a long drive a little more fun.
Both good options, one or the other ought to fit most situations.
Grigg
---All pictures---
Grigg #1089053 03/02/2015 7:54 PM
1 Offline
Also with more options for gear ratio's on the 14 bolt one needs to keep in mind the power source, my truck having the original stock 228 with all of it's 88 HP I'm concerned about being under-powered if I went with higher (faster) gearing than 4:10
Slick69 #1089067 03/02/2015 9:46 PM
Yes, good point on the gears and which engine you have.
I drove my 1 ton with 4.56 gears and a 55 model 235 a lot. I felt it was geared just right for around town and practical use hauling firewood and whatever else you can pile in a 9' bed.
Though for longer trips I am pretty sure 4.11 would have been great, and I may have gotten by with 3.73 and my limited power.
But back at home and normal use I think 3.73 would have been to much gear for the little 235.
All that to say 4.11 or 4.10 is probably about perfect for these old trucks without changing much else.
Grigg
---All pictures---
Slick69 #1089119 03/03/2015 2:22 AM
62401
We just updated the Tech Tip with some new info regarding donor axles. One of the big news flashes out of the update concerns brakes -- One of the experts (Barry) tells us the brakes are a bolt-on interchange between ALL HO52/72 axles ... (SRW to SRW, DRW to DRW, etc). Would someone like to confirm this?
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Slick69 #1089142 03/03/2015 3:31 AM
Stovebolt Photo Moderator
John. I have that rear sitting on the trailer we yanked your/our center section from. ODSS summer getaway project ? The shop is ready ! I'm game.
1947 - 3800 dually known as "Deadwrench"
Link to a few photos
In this world there are givers and takers. The takers eat well, the givers sleep well.
1Plowboy #1089207 03/03/2015 4:51 PM
Thanks for sharing.
John Milliman #1089214 03/03/2015 5:03 PM
Yes please confirm. Does that mean if I get the diff out of a 67-72 c20 with an Eaton (HO53) that I can also swap all of the brake hardware over to it too? I.E. backing plates and all the hardware attached to them and the drums?
AND
Let's say I wanted to ditch the duals on my 3800. Can I use the HO52 parts (axle shafts needed?)and then go to singles front and back? Ditch the front spacers or replace the hubs?
My mind is churning with options.
I was considering the 14 bolt for newer brakes, but 67-72 brakes are good enough for me.
Larry W.
Slick69 #1089219 03/03/2015 5:16 PM
There has been discussion on other threads about the 14 bolt axle that hubs and brakes (much more modern) are more or less interchangeable with the old Eaton axles as well.
I do not recall the details or troubles but I do remember it being more or less possible with not a lot of effort.
So if you want even newer brakes- then those on a 14 bolt are sure something to look into.
---All pictures---
Grigg #1089224 03/03/2015 5:30 PM
Good to know too. Thanks,
I was reading "that" thread just now and unless I read wrong, there is a wheel bearing size issue that requires machine work. Now that thread is very confusing because of all of the tangents it went off on, so I could have gotten it wrong.
If it turns out that the HO53 brakes will work on the HO72, I'm in. Especially if there is a way to do the duals from one.
Larry W.
Slick69 #1089245 03/03/2015 8:43 PM
Right, these brake and axle component swapping threads tend go get off on tangents and or not wrapped up. I am guilty of that myself, start on a project and something more important comes up. Then a year or three later I forget where I was and have to start over again.
It takes a lot of work to test, document, and report back on these swapping ideas.
Grigg
---All pictures---
Grigg #1089515 03/05/2015 1:37 AM
[i]
Grigg
Grigg and Shade Tree. Understood. Just to clarify, I meant no offense to anyone and the tips and research are VERY appreciated. I have caused a few tangents myself. I just get confused easily. People will always ask about their specific situation as will I.
Like this... LOL.
If I can find a way to swap my 1953 3800's HO72 5.14's for 4.10's from an HO53 AND put newer brakes on the HO72 while keeping my duals AND put disc brakes on the stock front axle AND have the front and rear bolt patterns match AND fit a modern 1 piece wheel... I'll be happy. LOL LOL Sounds ridiculous, but that is the real situation. My head hurts.
Larry W.
Slick69 #1089563 03/05/2015 5:13 AM
Sounds like a good plan and all possible.
The wheels I'd look for are 19.5", and run 8R19.5 tires.
Speaking of tangents...
Grigg
---All pictures---
Grigg #1089907 03/07/2015 1:55 AM
Thanks Grigg.
Standard 8 0n 6.5 pattern I assume? I can't measure, I wont have the truck until Sunday am.
I haven't looked at it all yet, but you have some nice tangents there!
Larry W.
Slick69 #1089922 03/07/2015 2:48 AM
Correct, found on GM and Ford step vans, 4x4 trucks, and any other 3/4 or 1 ton you're lucky enough to find them on. Certainly not found on all of those possibilities though, also by chance.
---All pictures---
Grigg #1089928 03/07/2015 2:59 AM
Cool,
Not sure I would have thought of the step vans, but they do have duals I guess. I think I saw some 19.5's on CL recently. I'll have to look again.
Thanks Again,
Larry W.
Grigg #1089933 03/07/2015 3:18 AM
Grigg
What about 16's Grigg? Too small? Look funny? Clear the brakes, with or without disc brakes? I think it has 18's now and they pretty much fill the front fenders from what I can see in pictures of it.
Larry W.
Slick69 #1089934 03/07/2015 3:26 AM
Not sure of the lug pattern, but I also found this set of 6 wheels and tires.
Looks like they are 8-17.5's. Not sure how common of a size that is but they seem pretty cheap for the condition.
Larry W.
Forgot the link.
https://jacksonville.craigslist.org/pts/4893368563.html
Slick69 #1089952 03/07/2015 5:20 AM
If dual wheel and you had 18" wheels you may not fit 16" wheels over the brake drums. Have to try and see
17.5" is also tubeless and desirable because of that but a little small I think.
In my opinion 19.5" wheels and 8R19.5 tires being 32-33" tall and still quite skinny just look appropriate on an old 1 ton.
Nothing wrong with the original wheels and tires but if you do want tubeless; 19.5" look "just right"... To me
---All pictures---
Grigg #1090095 03/07/2015 11:27 PM
Ok, Thanks.
Thought you might have tried them before. Been doing some looking and the P30 19.5's I'm finding have platinum rims or some such thing. LOL If the rims on mine look OK, I may just stick with those, at least for the near future. I don't have a grand plus to drop on used wheels and tires right now.
Larry W.
Moderated by  Dusty53
