3 members (Stewart2, Hanks custodian, 1 invisible), 64 guests, and 10 robots.
Topics128,014
Posts1,055,324
Members48,419
#109008 03/29/2004 10:01 PM
I have recently bought a small 4 1/2" angle grinder, cheap but effective. Now I want to use it for cutting so I bought some thin cutting wheels. My original arbor does not clamp the thinner discs because the inside collar bottoms first. Do they sell different depths of arbors for this ?
1951 1 Ton Completed
#109009 03/29/2004 11:55 PM
smile smile
Mine has a washer that is stepped toward the center to a greater thickness to use to hold a thinner disc or cutting wheel.
I would think it should have come with one.
Check with the manufacturer and see if they sell one for use with the grinder you got.
#109010 03/31/2004 2:49 PM
The inside collar should slide off and turn around. At least mine does.
#109011 04/06/2004 6:46 PM
Don't forget a face shield and some gloves! grin
#109012 04/07/2004 12:48 AM
My inside collar doesn't work that way because the bottom side mates with two flat sides. However, I have found different thicknesses of upper collars.
#109013 04/07/2004 6:39 AM
Those electric angle grinders are a great tool but they don't do everything. They are clumsy as heck when it comes to cutting. If you want a nice tool to cut sheetmetal get yourself an air "die grinder" with a cut off disc, not that is a great tool for precision cutting.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
