3 members (FishinToms53, KEVINSKI, mick53), 89 guests, and 3 robots.
Topics128,126
Posts1,056,353
Members48,441
#1089983 03/07/2015 10:00 AM
First, I am new to cars or trucks of this vintage. I have been restoring Corvettes for many years. Recently I purchased a 1941 1/2 ton pickup. The truck runs and drives and is in great shape with no rust to speak of.
When buying this project, I did not give any thought to the drivability of this truck on highways we have here in New Jersey.
I am in need of advice as to how I can change the rear differential to a ratio higher than the 4:11 that I think is in the truck at this time.
I would like to keep the remainder of the original drive train.
Thanks for any and all help.
Ed
ODSS Lawman
ODSS Lawman
Welcome to Stovebolt Ed!
The 4:11 ratio was the smallest that came on your vintage truck. There are a few options. Keeping the enclosed driveline will prevent having to change the transmission. I do not think the 3:55 gearset will fit in your rear axle. That being said, I have installed a third member out of an AD truck in your vintage. If you can do that, then you can get the 3:55 gears and be on your way.
Your truck will do highway speeds now once everything is in good working order. However the noise may be intimidating!!!
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Thank you for the response. Now let me show my true ignorance of this subject. What does AD stand for?
ODSS Lawman
ODSS Lawman
AD = Advanced Design Series
1947.2-1955.1
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Riding in the Passing Lane
The way I understand, you can use the 3rd member from a 50-54 pass car with powerglide. It has the 3:55 gears in it.
1972 Chevy c10 Cheyenne Super
Thank you for the information. I shall start my search.
Ed
I kind of remember things a bit different. If you are looking for a 50-54 car differential, I believe you will need to replace the entire differential, the pumpkin will not fit the truck differential.
3:55 after market gears are available and will fit 41 1/2 ton differentials. They are available from vendors such as 'Patricks'.
Thank you so much. I placed a call to Patricks but didn't get to talk to anyone. I will try again later.
I just spoke to the gentleman at Patricks who has indicated that a ring and pinion is available for the 1941 half ton truck and can be installed in the current set up.
Thanks to all for the help.
Ed
