| | | Forums66 Topics128,052 Posts1,055,726 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 14 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 14 | Is there a source for steel replacement running boards for the 1/2 ton 41-46 chevrolet pickups? I can only find fiberglass when I do a search?? TIA
"Life is tough.....it's even tougher if you're stupid" ~ John Wayne
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I got a pair of steel boards with the 46 I recently bought. They are not like the originals. Where the originals curve to the form of the cab the new steel ones are straight and do not match up correctly. I was going to use them on my 41 but went with the fiberglass which match nicely. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | There are some on ebay
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Feb 2015 Posts: 14 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 14 | Dennis, Thet boards I found on the e appear to be the short boards, & not the full length 1/2 ton type. Did I miss something or are you referring to a reproduction smooth board? Thanks!
| | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Brand new steel 41-46 OEM style (with ribs etc.) running boards for short and long beds are not manufactured by any vendor. Smooth running boards are available. Original running boards can be pricy on Ebay and the short cut-off style for the bigger trucks seem to be more available. It will take some patience and a cash outlay. It seems that people that use the fiberglass repro's like them for what they are.
| | | | | Joined: Feb 2015 Posts: 14 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 14 | Thanks Tom.....I understand they will not be cheap. Very familiar with that law of supply/demand. [email protected]Thanks!
| | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Just for your purchase pleasure - the short bed running boards are approximately 83" long. The long bed running boards are approximately 96" long. Don't do as I did and receive a long bed set when I needed a short bed board. No problem selling them though... | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | All parts offers, requests, etc. must be done in the swap meet.
Thanks. | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | I see them on ebay all the time, All styles too. Theres a guy in MN who parts 41-46 often. | | |
