3 members (RLB, Oswald, GRNHydra),
86
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 9 Junior Member | | Junior Member Joined: Mar 2005 Posts: 9 | Living in Lovely winterpeg manitoba has taken its toll on my old truck. Somebody must have installed new floorpans into thier old advanced design. What was it like? Any other chronic rustout places to look for on the old girl? Anyone looking to give away some floorpans? thanks, ollie | | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | what year? are you in the process of restoring? is the cab off? more detail please!~!! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Well, if it is the complete front floor pans, then you have to consider the surrounding metal. There are cross member peices attached underneath that hold the front cab mounts, rockerpanels, toe board and inner kick panels. That is the short list. I am doing the complete list so that is how I can remember! | | | | | Joined: Jun 2002 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 272 | well..... I am getting ready to do the driver side of my truck.
There are several holes so that I can not replace individually so it looks like the whole side will get cut out and redone.
I have the cab sitting on the frame but it is not bolted down. Since I will be ctiin out one og the cab mounts I think if the other 3 are intact and bolted it may force the cab to tweak some.
I bought a MIG welder in January and I am practicing with it. I have been running beads on anything I can get my hands on. I am not using gas at this point. I have welded a few pirced of 1/2 inch square tube together and yesterday i welded some trimmings from a patch panel together that I could not break apart so I thinkI am getting dangerously close to being able to do the floor.
I plan to break/cut the spot welds between the toeboard and the floor pan. Then cut from the toeboard to the seat fram along the trans opening.
I I will do my best to document and place my results here.
I have never welded anything important before ant this is my first truck so If I am able to get this done with no bodily harm to me or the truck anyone can. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If this is a cab with the two shackles at the rear, you could attach a temporary brace on the front side of the firewall, resting on the frame. That is how mine is supported. It is imprtant to make sure that the rear of the cab clearance to the frame at the rear, is the same on both sides. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The main thing to look out for is to make sure the doors still fit after you do all your adjustments. Fit the doors, then brace the cab by tacking braces across the doorways before you take the bottom off the cab. That should keep the doorways square so you can fit the doors back up when you put the cab back on the frame.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | |
