Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (51sub), 187 guests, and 7 robots.
Topics128,288
Posts1,058,578
Members48,492
#1089707 03/06/2015 12:47 AM
I have a 49 3100 and want to get the tank out of the cab. Does anyone have any suggestions as to a tank I could place between the frame under the bed? Thanks for any suggestions.
Why would you want that?
There can't be a safer place for the fuel tank. It's protected
by a lot of crushable steel in case the truck is hit from any
angle.
The last place I would want a tank is in the rear where if I got
A-holed I'd be sitting in the middle of a pool of flaming fuel.
The early side mounted tanks are just as bad.
dg
Denny G
Sandwich, IL
yeah, what Denny says, if it's currently stinky you need to re-do the filler rubber bits, including the gasket on the cap - if you think you'll gain room in the cab, study it more carefully .... if you insist on replacing the spare tire with an "IED", you need to measure up where you think it'd fit and check the wreckers for something that looks close, then figure out how to rig a filler and find a 30 ohm sending unit for it to drive your original gauge
I am not recommending moving the tank out of the cab, but Jim Carter sells an "original specification" 47-55 panel-body fuel tank that fits between the frame rails and leaves space for a spare tire carrier.
You'd have to devise a way to hang the tank (or find panel-body hanger parts). Of course, you'd also have to figure out where/how to route/place the filler tube/cap?
Former BMW Rider
Former BMW Rider
IMHO, stock is always the way to go. However, I purchased this kit, MEG159 for my '47. I see in the Jim Carter catalog the kit is 'billed' as a New Gas Tank Conversion. In fact it's also designed for 1949-53 Chevrolet/GMC 1/2 ton owners that want to get the gas tank out of the cab!
It was a smooth installation in my 1947......
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
Appreciate all the input, after looking it over with a different perspective, especially the one about the safest location on the truck, and actually not gaining hardly any room in the cab, I think I will leave it where it is and just get new rubber for it. Thanks again for the advice
People often complain of a gas smell in the cab. It shouldn't
have any, period!
As already posted, replace the rubber sleeves for the vent and
neck, the gasket at the sender, and the filler neck grommet if
it's all dried out and cracked, then don't over fill the tank
or let it set in the sun right after filling.
And......if the tank ain't leakin' you won't have any gas smell
in the cab.
dg
Denny G
Sandwich, IL
