| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 39 Member | | Member Joined: Feb 2001 Posts: 39 | Is there a "chrome" or bright silver spray paint that dries really hard? it seems these chrome-like paints are so easiler scratched and very soft even when completely dry. thanks
1948 GMC 250 Series Flatbed
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | You need to put a good clear coat over it. I have never seen one that will hold up. I use it on parts that where cad. plated.. Ray | | | | | Joined: Feb 2000 Posts: 50 Member | | Member Joined: Feb 2000 Posts: 50 | I use Eastwoods "Almost chrome" powder coat. It seems to work fine, it hasn't been on longer than about 7 months but still looks good. :p
'52 Chevy 5 window, it ran when I parked it '53 Chevy 5 window, running the streets with me. '55 Massey-Ferguson, tearing up the dirt '89 Harley FXSTS, suicide clutch '92 Harley FLSTC, equal time with the '89
| | | | | Joined: Feb 2001 Posts: 41 Member | | Member Joined: Feb 2001 Posts: 41 | I noticed the other day that Caswell Plating ( http://www.caswellplating.com/) carries a Nickel plating kit called "Copy Chrome" that uses cobalt to make it harder and bluer like chrome. Don't know the first thing about it, maybe someone else around here has tried it. Kits start around $100. Ed | | | | | Joined: Feb 2000 Posts: 50 Member | | Member Joined: Feb 2000 Posts: 50 | Metal Man.... Yes I have the powder coat system, but I bought mine before they had the newer system. They have 2 now, the one I bought is the cheaper one now. I also have the heat lamp to cure the larger pieces. I think its worth the money.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | rat I know the initall cost is more to set up to powder coat,but what is the cost to P. coat a part VS paint? | | | | | Joined: Feb 2000 Posts: 50 Member | | Member Joined: Feb 2000 Posts: 50 | Its hard to tell cost. You don't use much powder so a can goes a long way. You use less powder than I thought you would use. The part you powder has to be down to bare metal. They come out looking real good.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Those rattle can " chrome " colors are ok , as mentioned the coat is soft. If you shoot a clear coat on top of these it etches into the top coat & turns it into a silver/grey color which defeats the purpose all together. Time to step up to the plate & pay your local chroming guy to do a job that will last for many years. | | |
