3 members (Ponchogl, baldeagle, elhippie64), 67 guests, and 11 robots.
Topics128,020
Posts1,055,345
Members48,420
#108958 01/14/2002 4:25 AM
Is there a "chrome" or bright silver spray paint that dries really hard? it seems these chrome-like paints are so easiler scratched and very soft even when completely dry. thanks
1948 GMC 250 Series Flatbed
#108959 01/14/2002 4:45 AM
Anonymous
Unregistered
Anonymous
Unregistered
You need to put a good clear coat over it. I have never seen one that will hold up. I use it on parts that where cad. plated.. Ray
#108960 01/14/2002 12:58 PM
rat Offline
I use Eastwoods "Almost chrome" powder coat. It seems to work fine, it hasn't been on longer than about 7 months but still looks good. :p
'52 Chevy 5 window, it ran when I parked it
'53 Chevy 5 window, running the streets with me.
'55 Massey-Ferguson, tearing up the dirt
'89 Harley FXSTS, suicide clutch
'92 Harley FLSTC, equal time with the '89
#108961 01/15/2002 12:11 AM
I noticed the other day that Caswell Plating (http://www.caswellplating.com/) carries a Nickel plating kit called "Copy Chrome" that uses cobalt to make it harder and bluer like chrome. Don't know the first thing about it, maybe someone else around here has tried it. Kits start around $100.
Ed
#108962 01/15/2002 12:34 PM
rat Offline
Metal Man.... Yes I have the powder coat system, but I bought mine before they had the newer system. They have 2 now, the one I bought is the cheaper one now. I also have the heat lamp to cure the larger pieces. I think its worth the money.
#108963 01/16/2002 2:50 AM
Anonymous
Unregistered
Anonymous
Unregistered
rat I know the initall cost is more to set up to powder coat,but what is the cost to P. coat a part VS paint?
#108964 01/16/2002 12:39 PM
rat Offline
Its hard to tell cost. You don't use much powder so a can goes a long way. You use less powder than I thought you would use. The part you powder has to be down to bare metal. They come out looking real good. smile
#108965 01/28/2002 4:23 AM
Anonymous
Unregistered
Anonymous
Unregistered
Those rattle can " chrome " colors are ok , as mentioned the coat is soft. If you shoot a clear coat on top of these it etches into the top coat & turns it into a silver/grey color which defeats the purpose all together. Time to step up to the plate & pay your local chroming guy to do a job that will last for many years.
