8 members (‘37ChevyPU, Hotrod Lincoln, Otto Skorzeny, CuzzFuzz, Shaffer's1950, SlimSix, TrknGMC, 1 invisible),
81
Mod | | | Forums66 Topics128,139 Posts1,056,451 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | Can anyone send me a couple of pics of the head liner installed in a '41. Any suggestions on the best way to accomplish this with a minimum of cussing and throwing things would be appreciated. | | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | Sorry it is a '41 not '42...started cocktail hour! | | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | pps who should I get the liner from/ | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I got the cardboard one piece liner, with lots of cussing discussing and then finally quitting I threw it away and made my own. It turned out nice with no cussing at all. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | What I did was form the tight bends on each end before you install. I have some pictures toeard the middle of the photos. I kept increasing the bend each day for a week. I had the two piece liner for a 46. I secured it strating from the center and worked toward each side. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Gerry, Below are the gory details of my venture with the cardboard headliner. Never again. https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=1008305&page=1I went with a fiberglass headliner from Classic Chevy, I think all vendors sell the same part manufactured by Repops (sp?). Installation was still a little tedious, but I am very happy with the results. Paul BTW, did you ever get your rear window retainer? | | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | Sounds like fiberglass is the way to go. As for the rear window I ended up piecing two broken frames to make one. Reinforced the insides with some split tubing and epoxied it. Pretty pleased with the outcome. | | |
