1 members (Hotrod Lincoln),
69
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | Over the next couple months, I would like to strip the interior and parts of the exterior of my '59 that have had way too many coats of paint. Also I want to strip the old clear coat from an old Airstream, so I can polish it. It looks like some of the new water based products, like Zero Rust's Removall would work for both jobs, so I could buy a larger quanty of one product to save money. I have never used strippers for anything like this, so I would like to hear what kind of luck any of you have had, so I could avoid any potential problems.
Joe
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
| | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | No problems - just don't rush it. I use Aircraft stripper and lay a plastic bag, like a dry cleaners bag, over the top. This traps the volatiles better than the wax that's in the stripper and forces it down into the paint. Cover the ground around your workpiece with masking paper, or something disposable. It's messy. And, at least with the Aircraft stripper, keep a hose handy - burns like heck when you get it on your skin. | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | i agree--don't rush it. plasic scraper is all you need to scrape it off. old clothes, and shoes--GOGGLES, and gloves. and most definitely water. bag up the mess and spray the floor to clean. aircraft stripper is good stuff. remember to wash off metal parts with water, dry, and light sand parts before priming.  | | | | | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | I have used paint stripper several times and several differant types. The best and strongest I have found is the KleenStrip in the gold can from Home Depot think its about 12 bucks a gallon. Use a metal scaper it will eat a plastic one. I put it on with a horse hair brush let its sit 30 mins brush on anther coat then take a stiff bristle wire bush to it then scrap it or wash it off with a hose. And dont get it on you cuz it burns!
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces 2000 GMC Serria 1500 SL 4x4
| | | | | Joined: Feb 2001 Posts: 41 Member | | Member Joined: Feb 2001 Posts: 41 | I used a 3M paint stripping wheel to strip the paint and undercoating off of my frame and it worked really well. I'd say that, all in all, it was probably not much more labor intensive than chemical stripping.
Ed | | | | | | Anonymous Unregistered | | Anonymous Unregistered | When you put the stripper on cover it so it stays wet. garbage bag does good op plastic wrap.Most times you should try to leave it on for more than 3 hours and keep it wet. You use less stripper this way.I also use the cheap Home Depot stuff,seems to work great but i dont do a lot of customer body work. I make the customer have it blasted(really lucky around here we have the best around,NODAMAGE) | | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | Thanks for the replies. Sounds like it ought be good slimey fun.
Joe
Joe McNeel
| | | | | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | Don't forget - VENTILATION!
In addition to slimey burning-your-skin fun, this stuff is pretty bad on the cardio-respiratory system. Not as bad as POR-15, but there is some evidence that a number of guys have croaked of heart attacks while using this stuff.
Just keep the shop door open, and you should be OK. I usually do mine outside, that stuff has some good powerful fumes. :o
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
| | | | | Joined: Feb 2001 Posts: 164 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 164 | Can everyone say Methylene Chloride? One of the major health hazards in the Aircraft stripper..... Dying applying new $150 a gallon paint because of Isocyanates is one thing. At least it's new & shinney, but why kill yourself taking old worn out paint off when there is a non hazardous product available that doesn't make near the mess?? I make not one thin dime off the Removall water borne stripper sold either on our web site or thru the jobber network so take this info in the spirit offered, and save yourself all the health related grief you can by making smart choices in product purchases. Bruce Palmer Salem Or [email protected] | | | | | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | Heya Bruce - will RemovAll strip off POR-15?  Serious question... Also, how does it compare to the orange non-toxic stripper available at Home Depot, etc. Thanks! -Boyo
| | | | | Joined: Feb 2001 Posts: 164 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 164 | On the stripping issue, I don't know, nor do I know about the citrus based product. I'll bet you could maybe talk Irish into contributing a rattle can of Removall in the name of science. Go to [email protected] and do your best email whine and I'll back you up..... I do know that the parent company that makes the Removall has gradations for stripping paint from bridges which can be similar finish families to POR. I just can't get over how clean this stuff works. It soaks thru the film, offgasses O2 and lifts the finish in curly little sections vs the gooey slimey mess of dissolved paint with the Aircraft. By Garn, they ought to be paying me!!! Bruce Palmer Salem Or [email protected] | | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | Thanks Bruce. Along with being biodegradible, the idea of spraying it on, then pressure washing it off appeals to me. Especially on the Airstream, because I want to avoid using metal scrapers on the aluminum.To use this method, I would have to use something bio-degradable, because it would be likely some of the residue may get into the soil, though I would try to contain it as best I could. Mostly I wanted to hear from someone who had used it so I had an idea of how effective it was. I assume you still need to take the same precautions, ie. rubber gloves, goggles, etc.
Joe McNeel
| | | | | Joined: Feb 2001 Posts: 164 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 164 | Of course good safety measures are always in order around chemicals no matter how mild they may be. The Removall barely has any odor at all. Get it on your skin though and it will scare ya to death. It's such a rich oxygenator it'll suck the oil right out of your skin. You will think from the color difference that large chunks will start falling off, but in about 20 minutes the oil is replenished and the patch has disapeared. Just thought ya ought to be aware before ya see it for the first time and make the big wet one! Cheers.... Bruce Palmer Salem Or [email protected] | | |
