| | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 9 Member | | Member Joined: Feb 2002 Posts: 9 | I've run into another puzzle in getting my bed assembled (51 1/2 ton). I referred to the archives and see mention of plates attached to the cross sills. The text infers that these plates rest on the wooden spacer blocks, but they are not shown on the illustration. I just want to confirm that these "plates" are actually the pieces that slide onto the cross-sill channels, and that they must be drilled to allow the long 12" bolts to pass through the bedwood, cross sill, plate, spacer block and frame. Thanks in advance. | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Yup that's right. My plates came with the new cross sills and were already drilled (ChevyDuty). | | | | | Joined: May 2000 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: May 2000 Posts: 69 | Yeah. Usually they have a slot running diagonally across the plate so you've got some adjustment by moving the plate back and forth to line it up. You can even reverse the plate if you need to to line everything up for the bolt. If yours aren't drilled, I'd really recommend you get everything lined up perfectly (bed board, cross sill, plate, pad and block) before you mark the spot to drill the hole in the plate. | | | | | Joined: Feb 2000 Posts: 5,194 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,194 | If you don't want to drill through the wood you can put in a shorter bolt just through the plate. I did that then welded the plates to the cross members. Don't weld till you get them in place and lined up. I did all the mounting bolts that way except the rears. It makes for a cleaner bed. Joe | | |
