| | | Forums66 Topics128,131 Posts1,056,726 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 76 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 76 | I have a 1966 C-10 short step. I believe the rear end is the original 373 gears. The truck sat for five years before I bought it. After getting it running five years ago, the rear gears made a howling sound at 50 mph. Now, especially when I turn right, there is a loud banging sound coming from the rear end. I looked to see if the springs were seating properly, the u-joints are tight and the u-bolts were intact. All in all the visual inspection everything appears to be normal. In the last month, I had the rear axle seals replaced – and the shop that did the work didn’t note anything unusual. Any ideas why the banging sound is occurring? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | posi rear slipping - could try draining and flushing it and refilling, but you may be looking at a rebuild
Bill | | | | | Joined: Jul 2009 Posts: 76 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 76 | Actually Bill I kinda wondered. Before the rear seals were changed I had the GM additive for the rear end grease in there. The bang was less noticible but still there. I'm sure it has lots of miles on it... Should I do a ring and pinion change out or try a different axle? Tim-o | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I'd check with a rear end specialist, could be salvageable, but a hi-miler may be on its last legs
Bill | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I used a 12 bolt posi in my off topic Model A Hot Rod. It chattered really bad when I first got the car on the road. I ended up using two tubes of GM posi additive to get it to stop chattering. And yes, the posi still works, as is evident by two black tire marks when I put my foot heavy on the foot feed.  | | |
