1 members (UtahYork),
80
Mod | | | Forums66 Topics128,049 Posts1,055,637 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 54 | I am wiring my 56 Chevy pickup after taking it apart a few years ago. I am trying to figure out where the wires for the turn signals plug in to. I found several wiring diagrams but none show the turn signal wires. Even the service manual I have omits the replacement of the switch. Any clear diagrams out there? | | | | | Joined: Mar 2014 Posts: 195 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 195 | Just a quick google search: Is this what you are looking for? I have a seven wire switch on my 51 truck with this wiring: Click. Colors do vary from unit to unit.
Chevrolet 3100 Year: 1951 engine: inline 6 217CI Transmission: Manual 3-Speed. 12Volt. | | | | | Joined: Jan 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 54 | Yes that is very helpful. I did not find that drawing. Thanks | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If you are reassembling a factory turn signal set-up, there will be connector plugs near where the wires exit the column. If not you may have some rewiring to do. Turn signal tech tip may help. | | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | I just worked on my turn signal/brake light wiring. If you are using your original wiring harness the 8 wire plug should be dropping down from behind your column from behind the dash. If you are using an original or new original replacement turn signal switch harness the color of the wires will just need to line up (turn signal housing Guide D2-53). If you are using an aftermarket one that might not be the case. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | signals were an optional accessory, found in the accessory installation manual - factory wiring diagram about the 4th page Bill | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | Here is the way my 1956 Chevy 3100 was wired I made this cheat sheet
1956 Chevy 3100 Original Factory Wiring Headlamps………………………………………………………………………………………………………… High Beam 20 Ga. Light Green Light green from “U” on the dimmer floor switch Low Beam 20 Ga. Tan Tan from “L” on the dimmer floor switch Ground 20. Ga Black To the ground chassis Parking/Turning Signal Lights…………………………………………………………………………………... Park Lamps 20. Ga Violet From the “PK” on light switch Horn……………………………………………………………………………………………………………….. Horn 14 Ga. Black From terminal “H” on the horn relay Lighting Switch Assembly………………………………………………………………………………………... Terminal “GRD” 20 Ga. White Plain wire to the dome light Terminal “D” 20 Ga. Orange Ribbed wire to the dome light Terminal “T” 20 Ga. Black To the tail lamps Terminal “BAT” 14 Ga. Red From the terminal “BAT” on the ignition switch Terminal “BAT” 16 Ga. Red To acc. jct. block Terminal “S” 20 Ga. Orange To the brake petal switch stop lamps Terminal “PK” 20 Ga. Violet To the parking lamps Terminal “H” 20 Ga. Light Blue To the floor dimmer switch Headlamps Terminal “PL” 20 Ga. Gray To the 5 instrument lights (3 in the cluster, 1 in the ignition, 1 in the heater control panel, & 1 in the cigarette lighter) Terminal “PL” 18 Ga. Gray To the acc. jct. block Brake Petal Switch ……………………………………………………………………………………………… In 20 Ga. Orange From Terminal “S” on light switch assembly Out 20 Ga. Nat. White To stop lights Floor Dimmer Switch…………………………………………………………………………………………….. Terminal “BAT” 20 Ga. Light Blue From terminal “H” on the light switch Terminal “L” 20 Ga. Tan To the low headlight beams Terminal “U” 20 Ga. Light Green To the high headlight beams Terminal “U” 18 Ga. Light Green To the high beam indicator light in cluster Temperature Gauge In 20 Ga. Pink From terminal “IGN1” to the temperature gauge Out 16 Ga. Dark Green From the temperature gauge to the sending unit Gas Gauge Tank Unit…...………………………………………………………………………………………... Gasoline Meter 20 Ga. Brown Attaches to the bolt on sending unit from the gas meter Ground 20 Ga. White Attaches to screw on sending unit to the ground chassis Stop Lights………………………………………………………………………………………………………… In 20 Ga. Nat. White From the brake petal switch In 20 Ga. Black From terminal “T” on the light switch assembly Cigarette Lighter………………………………………………………………………………………………….. In 16 Ga. Red From the terminal “BAT” on the ignition switch In 20 Ga. Gray To light Ignition Switch……………………………………………………………………………………………………. Terminal “BAT” 16 Ga. Red To cigarette lighter Terminal “BAT” 14 Ga. Red To terminal “BAT” on lighting control assembly Terminal “IGN2” 20 Ga. Dark Green To the coil and resister on the fire Terminal “Start” 20 Ga. Violet To the solenoid switch on the starter Terminal “IGN1” 20 Ga. Brown To the resistor on the fire wall Terminal “ACC” 20 Ga. Pink To flasher Terminal “IGN1” 20 Ga. Pink To gasoline gauge Terminal “ACC” 14 Ga. Pink To the acc. jct. block
Gasoline Meter……………………………………………………………………………………………………. In 20 Ga. Pink From the terminal “ACC” on ignition switch Out 20 Ga. Brown To gas sending which attaches to the bolt Instruments Lights 4 lights in gauge cluster……………………………………………………………………. 20 Ga. Gray From the terminal “PL” on light switch Acc. Jct. Block…………………………………………………………………………………………………….. 16 Ga. Red From terminal “BAT” on the lighting switch assembly 14 Ga. Pink To terminal “ACC” on the ignition switch assembly 20 Ga. Gray From the terminal “PL” on the lighting switch assembly Horn Button……………………………………………………………………………………………………….. 20 Ga. Tan From the terminal “S” on the horn relay Horn Relay………………………………………………………………………………………………………… Terminal “H” 16 Ga. Black To the horn Terminal “B” 14 Ga. Red From terminal “B” on the voltage regulator Terminal “S” 20 Ga. Tan To the horn button Voltage Regulator………………………………………………………………………………………………… Terminal “B” 14 Ga. Red To terminal “B” on the horn relay Terminal “B” 12 Ga. Red To ammeter Terminal “A” 14 Ga. Brown From terminal “A” on generator Terminal “F” 20 Ga. Dark Blue From terminal “F” on generator Turning Signal Assembly in Steering Column………………………………………………………………….. 20 Ga. Yellow From the flasher 20 Ga. Dark Blue To the right front turn signal 20 Ga. Dark Blue To the right front turn signal indicator 20 Ga. Light Blue To the left front turn signal 20 Ga. Light Blue To the right front turn signal indicator 20 Ga. Pink To the white stripe wire going to the left stop lamp 20 Ga. Purple To the white strip wire going to the right stop lamp 20 Ga. White To the stop lamp floor petal switch Flasher……………………………………………………………………………………………………………... 20 Ga. Pink From terminal “ACC” on the ignition control switch 20 Ga. Yellow To the turning signal assembly in the steering column High Beam Indicator light in Instrument Cluster……………………………………………………………… 18 Ga. Light Green From the wire attached to “U” on the dimmer switch Coil………………………………………………………………………………………………………………… Positive 20 Ga. Dark Green From Terminal “IGN2” on ignition switch Negative 20 Ga. White To screw terminal on distributer body Ammeter…………………………………………………………………………………………………………... Positive 12 Ga. Red From terminal “B” on the voltage regulator 12 Ga. Black To the battery terminal on the starter solenoid Resistor…………………………………………………………………………………………………………….. 20 Ga. Dark Green To the coil and to the terminal “IGN2” on ignition 20 Ga. Brown From terminal “ACC” on the ignition switch 18 Ga. Brown To the windshield wiper switch Generator………………………………………………………………………………………………………….. Terminal “F” 20 Ga. Dark Blue To terminal “F” on the voltage regulator Terminal “A” 14 Ga. Brown To terminal “A” on the voltage regulator Starter……………………………………………………………………………………………………………... Solenoid Winding 20 Ga. Violet From terminal “Start” on the ignition switch Battery Terminal 12 Ga. Black From the ammeter Battery Terminal 4 Ga. Black From the battery Starter Body 6 Ga. Copper Strap to chassis Battery……………………………………………………………………………………………………………... Positive 4 Ga. Black From positive side to the battery terminal on the starter Negative 6 Ga. Copper Strap Negative side of battery to the chassis Deluxe Heater/Vent/ Blower……………………………………………………………………………………... Switch Red From acc. jct. block Switch Brown To blower motor Windshield Wiper………………………………………………………………………………………………… 18 Ga. Brown From resistor to the windshield wiper motor
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | |
