| | | Forums66 Topics128,134 Posts1,056,403 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 148 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 148 | I have 1954 3600 with Tom Langdon's dual carbs. It has a power booster also. I want to know where to hook up vacuum to it because I already have a fitting off the manifold for the booster. I don't think I should split that vacuum to the PCV system. Is there a place to pull it from the two carbs? There is another port on the carbs that pulls when throttle is opened. I don't think that's right. What do you all think? Thanks Sharon | | | | | Joined: Feb 2004 Posts: 29,814 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,814 | Just put a T in the line to the booster. You'll need full intake vacuum and a big enough hose to get a good gulp of the air in the crankcase every time the PCV cycles open. Your booster should have a 1-way check valve in it, so you're not going to lose vacuum to the booster as the PCV cycles. Jerry
| | | | | Joined: Jun 2013 Posts: 148 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 148 | Sounds good Jerry
Thank You | | |
