1 members (Thomaslb),
138
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 204 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 204 | i read the tech tip "need for speed" and was ready to begin my gear swap. in the article it says to check pumpkin for "10-41" stamp on it. my pumpkin doesn't,it has "3838365 gm 9-37 1967 2 1" will this work? what is the ratio? the man i bought it from told me it would work. i just want to clear any doubts. thank you ,brian
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | So the ratio there would be 37/9 = 4.11. Apparently they also made a 4.11 ratio besides the 4.10. Does the outside look exactly like yours? | | | | | Joined: Mar 2011 Posts: 204 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 204 | it does but i never put them side to side | | | | | Joined: Mar 2011 Posts: 204 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 204 | i just went under my truck and they look the same (the new one in question doesn't have a side plug, my old one does) casting numbers on the new one are: 3883379 side, hw03206 top, 3883354 near shaft. cast numbers on my old are: 8699535 side | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Apparently they also made a 4.11 ratio besides the 4.10. I'll have to do a quick check to be sure which is which, but one of those is for a Spicer 60 instead of the Eaton.
Bill Burmeister | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | One source says the rear ends with an "HW" code were 4.11's from '67-'69 C-20's. Could that correspond to your "hw03206"?
They apparently switched to a 4.10 in '70.
Still don't know if it would work for you.
I got this from the "Chevrolet Pickup Red Book." 1946-1972 Chevies by the Motorbooks International company (published 1993). I know there are some mistakes in this book, mostly omissions. It is kind of useful, though. I don't remember the book being mentioned in the forums.
1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | This might be a bit of a red flag. The "side plug" is actually an adjustment on a part that protects the crown gear assembly from flexing. That is part of the design of that rearend. Has anyone seen that rearend without that feature? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | As I recall, some 3/4 ton GM Trucks had Spicer rear axles, Chevies had Eatons.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That is for the most part, correct. GMC did use Spicers pretty much exclusively. With Chevrolet, though, it depends on what the options were. Generally speaking, 3/4 ton coil spring trucks had the Eaton, and leaf spring trucks got the Spicer, which is how GM lists them in the specs on the Heritage site. However, I have heard of sightings of leaf spring Eatons and coil spring Spicers. Also, GM does show a listing for a 1/2 ton with the Spicer rear and coil springs, but only with the 396 engine.
Bill Burmeister | | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | We just updated the tech tip with some excellent info provided by Barry Charon on the different trucks and which ones to look for. Check it out!
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Barry Charon helped me out a bunch on some crazy 4X4 AD options. He has a lot of knowledge and is willing to share it. Carl
| | | | | Joined: Mar 2011 Posts: 204 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 204 | | | |
