1 members (Brian Moore), 95 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1088061 02/26/2015 3:30 PM
i read the tech tip "need for speed" and was ready to begin my gear swap. in the article it says to check pumpkin for "10-41" stamp on it. my pumpkin doesn't,it has "3838365 gm 9-37 1967 2 1" will this work? what is the ratio? the man i bought it from told me it would work. i just want to clear any doubts. thank you ,brian
1955 First series 3600 3/4-ton
"A Great Starting Point"
Follow the story and pix in the DITY Gallery
66flea #1088063 02/26/2015 3:41 PM
So the ratio there would be 37/9 = 4.11. Apparently they also made a 4.11 ratio besides the 4.10. Does the outside look exactly like yours?
1951 1 Ton Completed
truckernix #1088068 02/26/2015 3:50 PM
it does but i never put them side to side
66flea #1088098 02/26/2015 7:12 PM
i just went under my truck and they look the same (the new one in question doesn't have a side plug, my old one does) casting numbers on the new one are: 3883379 side, hw03206 top, 3883354 near shaft. cast numbers on my old are: 8699535 side
truckernix #1088112 02/26/2015 9:12 PM
I'll have to do a quick check to be sure which is which, but one of those is for a Spicer 60 instead of the Eaton.
Bill Burmeister
66flea #1088327 02/27/2015 9:56 PM
One source says the rear ends with an "HW" code were 4.11's from '67-'69 C-20's. Could that correspond to your "hw03206"?
They apparently switched to a 4.10 in '70.
Still don't know if it would work for you.
I got this from the "Chevrolet Pickup Red Book." 1946-1972 Chevies by the Motorbooks International company (published 1993). I know there are some mistakes in this book, mostly omissions. It is kind of useful, though. I don't remember the book being mentioned in the forums.
66flea #1088527 02/28/2015 7:38 PM
This might be a bit of a red flag. The "side plug" is actually an adjustment on a part that protects the crown gear assembly from flexing. That is part of the design of that rearend. Has anyone seen that rearend without that feature?
66flea #1088836 03/01/2015 10:41 PM
Crusing in the Passing Lane
As I recall, some 3/4 ton GM Trucks had Spicer rear axles, Chevies had Eatons.
66flea #1088840 03/01/2015 10:56 PM
That is for the most part, correct. GMC did use Spicers pretty much exclusively. With Chevrolet, though, it depends on what the options were. Generally speaking, 3/4 ton coil spring trucks had the Eaton, and leaf spring trucks got the Spicer, which is how GM lists them in the specs on the Heritage site. However, I have heard of sightings of leaf spring Eatons and coil spring Spicers. Also, GM does show a listing for a 1/2 ton with the Spicer rear and coil springs, but only with the 396 engine.
Bill Burmeister
66flea #1089122 03/03/2015 2:29 AM
62401
We just updated the tech tip with some excellent info provided by Barry Charon on the different trucks and which ones to look for. Check it out!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
66flea #1089129 03/03/2015 2:51 AM
Barry Charon helped me out a bunch on some crazy 4X4 AD options. He has a lot of knowledge and is willing to share it.
Carl
52Carl #1094552 03/30/2015 1:15 AM
review
