1 members (delky),
130
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I primed my bike tank tonight. It's looking pretty good, but I have a few spots I didn't sand flat enough on the filler. It's off a 1974 Honda CB750K4. The emblems fit over the holes on the side. Here it is: [img]http://home.comcast.net/~josiahbartlett/pictures/tank.jpg[/img] I used Martin Seniour 2k primer with a Taiwanese gravity feed HVLP gun with 1.5mm tip set at 50 psi. I didn't bother to mask off the cap because I am replacing the gasket anyway. The inside is lined with POR-15 fuel tank sealer.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Feb 2000 Posts: 987 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 987 |
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If you had Irfanview you could resize your pictures. Then even people with dial-up connection could see them. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Sorry, sometimes I forget about my picture size because I usually resize them with html tags, which the SBP does not allow. I'll shrink them next time.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I never have trouble downloading with my dialup, it is still only seconds but I hate scrolling side by side. Especially a long thread to read each sentence and scroll side to side, forget it.
54 3100 with 235 62 flatbed dump C60 with 261
