| | | Forums66 Topics128,082 Posts1,055,964 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | I have a 1949 Chevy 1/2 ton. I bought it and it was so-so redone. I have never been able to get the doors to shut and have a decent gap. Also have to shut them really hard. Could it be possible that I have the wrong door latch / strikers on these doors? I've tried every way to adjust the hinges but still no luck. I need some advise. As always, thanks so much. Steven | | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | I've also tried to adjust the strikers and latches. Nothing seems to work. | | | | | Joined: Mar 2014 Posts: 154 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 154 | I have the same problem with my '49. I believe my door latches are reproductions installed, by the PO. There's been a lot of discussion about how there's nothing like the originals, but I'm still hopeful for a solution too.
Greg
Greg Brown
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Since you have a Photobucket account, put some pictures of the strikers and the part of the latch you can see in the door on the account and link them here. Those of us with that era ('47-'51)of door parts should be able to tell if they are correct. Then we can go from there. Kent
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Red 49 Truck,
Lightholder's Dad is correct. Pics would be a big plus to get started on the proper door latches and strikers. For what it's worth, I too have a late '49 3100 that I had the same problem with. I purchased aftermarket latches and strikers and had little to NO success. The latches were poor quality and I ended up returning them. I purchased two sets of strikers from two different vendors and after careful measuring of the riser for the safety catch I found that the aftermarket strikers were 1/8" higher than the original worn strikers I removed. Long story....short, I ended up buying a set of NOS door latches and NOS strikers. Lined everything up, adjusted the door gap on both doors with the hinge adjustments to specification from the 1948-1953 Chevrolet shop manual and the door close perfectly! Original GM parts do make a difference along with a lot of patience. Finding these NOS parts are difficult, but E-Bay, swap meets, and some parts dealers on the internet who have purchased old Chevrolet dealership parts inventory would be you best bet for these door latches and strikers. You could also post an ad in the "parts wanted" section of the Stovebolt forum and someone might have them.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | I have not bought these yet but they are on my radar for sure....I wont drive Howard Knapp until these are on the both doors... http://www.triquemfg.com/altman-easy-latch-kits/(page 1 all the way to bottom) It may not be for a perfect restoration but it will give a safe ride in that the doors will stay shut...I have heard nothing but rave reviews from all the folks that have put them in...this the bar that everybody else is gauged by. my smelly old 2 cents... MikeC 1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I have totally disassembled 4 latches, welded on metal where metal has been worn away and put them back together. I used a TIG welder. Usually the passenger side latches will be in better shape to give you a good idea what metal needs to be built up. Two of the latches where in very bad shape, but were restored to fully functional. Carl
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I'm with you on that Mike,although I have been driving mine. I just need to scrape up some cash but these are high on my 'to-do' list. It's the one thing that grates/embarrasses me is slamming the doors when I get to a show,it does get peoples attention though!  In fact the very day I picked up my truck when I bought it the passenger door flew open on the freeway. (It was on a trailer thankfully) 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | The reason why we have so many problems with original latches has little to do with the design of the latch. It has everything to do with the fact that the latches have been hammered into unworkable condition due to 50+ years of slamming into the strikers due to worn hinges from lack of routine lubrication of the hinge pins. The same would eventually occur to any kind of latch which you choose to install, if the hinges are not maintained. Carl
| | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Thanks for all the good tips. I will try to get some pictures of my strikes and latches. My doors shut and stay shut but like it was said above I have to slam them. Not good. Thanks again for all the tips. Steven | | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | you know, 52Carl, I believe you hit the nail on the head. How many of us now lub our latches and hinges? I do but probably not enough. Great food for thought. Thanks for the reminder. Steven | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Body Lubrication: "Many service stations [and owners] do not consider body lubrication as part of a normal lubrication job; therefore, body lubrication is often neglected." tsk, tsk, . . Print out and post in your garage. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You guys beat me to it. I can't tell you how many mis-aligned hoods with "bad" hinges and bad closing doors I "fixed" with white lithium grease back when I was a body man.
| | | | | Joined: Apr 2014 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2014 Posts: 28 | that has got to be the best and most thorough piece for fixing these trucks i have ever seen. do you have any more links to any/all of this quality for these trucks?
49chev6400.webs.com
