| | | Forums66 Topics128,266 Posts1,058,368 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 3 New Guy | | New Guy Joined: Oct 2014 Posts: 3 | I'm changing the starter on my 2 ton. I see this wire just hanging in that general area. When it gets close to the motor it arcs electricity. For all I can tell it comes over the engine to the driver side of the block and connects to a part in the block . I have a Goodwrench 350 . What the heck is this part, and where is this wire supposed to go? I need to get a good manual, but I'm hoping someone here can help me figure this out. | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy Tipidweller, welcome, please remember to tell us the year of truck you're asking about and any modifications it may have had, such as a switch from six to twelve volts. Is the wire in question hot all the time? The wire may be an alternator output wire if alternator equipped. What gauge is the wire, what size or type of terminal is on the end of the wire, what colour is the wire? | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | it sounds like you are just going to have to do this the old fashioned way. Just figure it out. Just saying "a wire hanging down by the starter" doesn't really mean anything to pretty much anyone. In the period of anywhere of 30-60 years (we have no idea what year your truck is) a lot of things can happen. Previous owners can (and many times do) really strange things, add devices, remove devices, repair, ruin, and/or otherwise disfigure things. A picture might help, with the information given we don't stand a chance. "connects to a part in the block?" Really?
| | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | There are wiring diagrams available online for many old vehicles. And even if your particular vehicle is not listed,one that is close in year may give you a clue.Search for old manuals.---Jack | | | | | Joined: Oct 2014 Posts: 3 New Guy | | New Guy Joined: Oct 2014 Posts: 3 | O.k thanks. I drive a 66 big bolt. I mentioned, it has a 350 Goodwrench crate motor. I figured: how many parts are built into the engine block? It's maybe a block heater? Anyhow, it don't seem to be hurting anything. Once again, thanks for the replies. | | | | | Joined: Dec 2008 Posts: 902 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 902 | Since it doesn't bother anything I wouldn't worry about it. BBBButt I would definitely tape up the end so it doesn't short against something and then cause a problem. JMO.
Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | |
