| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 23 'Bolter | | 'Bolter Joined: Feb 2015 Posts: 23 | ok so now I have a problem, LMC does not carry, or cover 1 ton panel parts, any one know where I can get parts, both sides from doors need the metal to repair, only way I see it I will need to fabricate my own parts, to replace them, once again any help would be grateful. thanks
Wylie johnson
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | wylie, you may want to try the Truck Shop in Ca. I would think the doors on your panel should be the same as the pickup. I know they cover your year. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I'm not sure if I understand your post. Are you talking about the front doors or the rear doors? The front doors should be the same as other trucks (pickups) including 1/2 tons. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | 4-5-6 chevy trucks can answer your questions,he's a member here on this site. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | 4-5-6 chevy trucks can answer your questions,he's a member here on this site. Yes, he can but he's not here anymore. | | | | | Joined: Mar 2005 Posts: 189 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 189 | Person-to-person discussions should be done in email or in Private Messages.
Last edited by tclederman; 02/26/2015 12:34 AM. Reason: by moderator - please make private transaction contacts in private
| | | | | Joined: Feb 2015 Posts: 23 'Bolter | | 'Bolter Joined: Feb 2015 Posts: 23 | the rear barn doors
Wylie johnson
