1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 504 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 504 | Hi everyone, Got another "down in the weeds" question for everyone. In the attached pic ( Brake line clip ) you can see the clip that I'm interested in. I have replacement brake lines and am wondering how to remove the line from that clip without damaging the clip. I am hoping to re-use it. Do you just pry up the end and slide the brake line out or do you have to remove the bolt from the axle/differential housing? If you do have to remove the bolt, does it ruin the seal on the differential? Sorry for the noobish nature of the question. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Remove the bolt/screw and unbend the clip from around the line. Unless it has been bent and unbent many times, it should not break or crack. If it breaks or cracks, you should buy replacement clips.
| | | | | Joined: Sep 2010 Posts: 504 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 504 | Thanks for the fast reply! I'm hoping to get out in the garage this weekend, if the temps come up a little. Crawling around on the cold concrete gets kinda rough sometimes! | | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | It's pretty simple to fabricate a new clip out of 1/16" thick X 1/2" wide steel flat stock if that one happens to break as you're stretching it. Just use a 20 penny nail as a bending template and roll the steel around it. I've made a bunch of them that way, and it's almost impossible to tell the difference from an original clip. Jerry
| | | | | Joined: Sep 2010 Posts: 504 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 504 | Great idea! If it breaks or is too gnarly when I get it off, that's what I'll do. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | To get to the "other" part of the post, the seal of the gasket under the cover will not be harmed when that bolt is removed. That bolt is too high to have any fluid drain from it so that is a plus. Even a lower bolt can be removed. That is the best way to drain the oil from the beast any way. If you don't want to drain, then put the bolt back in and snug it down. That gasket is cardboard and glued into place most of the time. Hotrod, good suggestion on the 20 penny nail. That and some vice work will get a nice clip in no time.
Steve H
