2 members (klhansen, Hotrod Lincoln), 89 guests, and 0 robots.
Topics128,050
Posts1,055,641
#1086813 02/20/2015 2:42 PM
I have a 49 suburban w clamshell doors. The "lifts" that hold open the clamshell were non existent when I purchased. Does anyone know of a vendor that repops these? I looked at past posts but could not find any references. I've also considered trying to retrofit new style lifts from current model hatchbacks so if anyone has done this please let me know what worked. Thanks
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
I
I Offline
from a post by 552burb- "I pulled a retractor out of my 55 TF burb. The part is made by Pullman. It has a part no. of 105-A. Below that are the numbers 9-111B."
53 Chevy 210 convertible; 55 GMC pickup; 57 GMC Suburban Carryall
49bourbon #1087109 02/21/2015 11:01 PM
Sir Searchalot
Sir Searchalot
Don't think any aftermarket. Ebay or wanted ad here. Otherwise there are all kinds of gas props/springs available in various lengths and poundages at FLAPS.
did you ever check into the ones elhippie spoke of ?
lift slides
1951 3100 Chevrolet
Google the Pullman manufacturing co. They are still in business making sliding window retractors. The part number above is correct. Call the company to place the order. The normal retractors have a reach of 46". On the TF Burbs you need a 48" reach. I assume it is the same for yours. Just let them know you need the extended version. The hard part is finding good cables. Right now I don't think anyone makes them. If you have good cables your are 3/4 the way there. Good luck.
Larry
Looks like he wants the lift arms and not the retractors.
1951 3100 Chevrolet
Thanks guys . I did get the retractors from Pullman for the lower shell and they work great. I did not get the elhippie lifts as when I spoke w them the brackets would have to be cut off and rebuilt and I don' t have the original lift brackets. I may have to go that way but leaning toward gas lifts as my burb is not all original but a restomod w new running gear. With swap meet season upon us please keep me in mind if you stumble upon some.
I
I Offline
Would 55-57 Chevy lift arms be adapted to work? There's a pair of those on Ebay right now..
Pm sent to you 49bourbon
1951 3100 Chevrolet
