1 members (Truckrolet), 154 guests, and 2 robots.
Topics128,149
Posts1,056,818
Members48,456
On my retro Good Humor truck, I have the 235 single exhaust.Theres a bracket comes down with a slot and a bolt hole on it. I believe this holds the round exhaust pipe. Using a half circle clamp the one end goes in the slot and the other end is secured at the bolt end.Does any one have a picture of it? Right now I`m using my old exhaust setup. Plan on buying a Waldron exhaust setup. Steve D
http://i1305.photobucket.com/albums/s554/icecreamman55/005_zpsma0um9cl.jpg[/IMG]
I'm just using a big hose clamp
...pic...
I think denny has an original set up
...Denny's web site...
Two pictures above are off 50's.
Gus, looks like we have the same muffler style.Like the glass pack.I`m going with the standard truck muffler from Waldron exhaust. None of the vendors carry the complete setup. I did find similar setup from Scott Walker and ordered the kit.The strap loops in the one side of the slot and wraps under the muffler to the hook and under the muffler and the bolt tightens up the strap.So the muffler is tight against the support.
http://i1305.photobucket.com/albums...y%20strap%20to%20muffler_zpsawh6ss3s.jpg[/IMG][/URL]http://i1305.photobucket.com/albums...k%20strap%20to%20muffler_zpsj54zlnv5.jpg[/IMG]
do you have that part number for the kit?
Gus, (walker 35745 Exhaust Muffler Strap) summit racing has it for $12.00 comes with two hooks and the strap. I`m not sure if the strap is long enough , it looks to be and I did order one. Very simple design.
http://i1305.photobucket.com/albums/s554/icecreamman55/wlk-35745_xl_zpsd4jgx4z7.jpg
thanks
that looks alot better than a hose clamp
