2 members (carbking, RLB),
157
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | I have a 1952 Chevy pickup i am currently working on. I recently purcahsed a 1954 235 complete with trans. The mounts for the bell housing to frame are at an angle VS the ones I have for my 51 and 52 trucks. can I just swutch them out and is the one for the 54 at an angle? I am thinking maybe it came out of a Car?? Paul | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Angled mounts started in '54. You must use the earlier bell housing to put a '54 engine in a pre'54 truck. Excellent choice of engine too since it won't need water pump alterations like later 235s do. | | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | I am hoping it works. its so clean and oil looks good also been converted to 12 volt. Can I take off the bell housing without removing the clutch? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | No, the clutch and flywheel must be removed to access a couple of bolts. | | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | thats what I thought thanks | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | well you can but it means that you have to disassemble the whole motor. I had to because on my motor because it was stuck and almost a 235 boat anchor. Cletis gave you the correct answer which is No unless you can not rotate the motor to remove the clutch.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | |
