7 members (dt235sd, 3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, 1 invisible), 88 guests, and 1 robot.
Topics128,074
Posts1,055,910
Members48,429
#1086864 02/20/2015 6:50 PM
I have a 1952 Chevy pickup i am currently working on. I recently purcahsed a 1954 235 complete with trans. The mounts for the bell housing to frame are at an angle VS the ones I have for my 51 and 52 trucks. can I just swutch them out and is the one for the 54 at an angle? I am thinking maybe it came out of a Car??
Paul
Angled mounts started in '54. You must use the earlier bell housing to put a '54 engine in a pre'54 truck. Excellent choice of engine too since it won't need water pump alterations like later 235s do.
I am hoping it works. its so clean and oil looks good also been converted to 12 volt. Can I take off the bell housing without removing the clutch?
No, the clutch and flywheel must be removed to access a couple of bolts.
thats what I thought thanks
well you can but it means that you have to disassemble the whole motor. I had to because on my motor because it was stuck and almost a 235 boat anchor. Cletis gave you the correct answer which is No unless you can not rotate the motor to remove the clutch.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
