0 members (),
107
Mod | | | Forums66 Topics128,265 Posts1,058,365 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Took a turn out of the driveway and the steering was super sloppy. The right front tire was at an angle. Towed to mechanics he says might not be able to find oversize King pins......the LH side was done five years ago and they found pins. Can anyone tell me who still has oversized King Pins. 3100-235-1954 orginal front axel. Thanks for your help! Steve | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | Most looseness with the kingpins is caused by bushing and or spindle wear. Oversize kingpins are used for problems with the axle bore. It is very unusual to do the kingpin on only one side of the truck. Maybe your mechanic could give you a little better explanation of what he thinks it needs. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | A king pin discussion in the engine shop? What's up.
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Justhorsenround is correct. This post needs to be in the driveline forum or general truck talk.
Without seeing photos....you got pics? I would guess that the bushings around the king pins are worn out or gone, or you've got a spindle problem as Fred has noted. Pics would REALLY help with diagnosis. Both king pins need to be replaced as a set, right and left. Suspension parts as a rule should be replaced in sets whether it is front or rear. Look at this as a job per axle.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Yep....messed up should be in drive line .....should put on my glasses...sorry about that. I don't have pictures because it was towed. I'll ask about doing both sides. I've never had to do kingpins. Where is a good place to buy them..Napa....Auto Zoned Out.....O'really....? Thanks | | | | | Joined: Aug 2011 Posts: 229 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 229 | I have seen them at Rock Auto and NAPA. | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Correct me if I'm wrong,"I usually am", Don't you have to remove the old ones first and measure ID before purchasing new ones? | | | | | Joined: Mar 2010 Posts: 10,335 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,335 | I would say that you definitely should take the old ones apart first to check where the kingpin goes through the axle. If the kingpin is tight in the axle, you do not need over-sized kingpins. You will need standard sized kingpin kit. Most of the time you only really need the bushings, but they don't sell them without the kingpins. You will need to check the bores in the spindle where the kingpin bushings go to make sure that the spindles aren't worn excessively. You can use your new bushings to see if they wobble in the spindle bores. If they wobble, you will need to find a spindle in better condition. Carl
