9 members (Phak1, Bill Hanlon, Rusty Rod, TUTS 59, Napco Man, Cosmo, ndkid275, 2 invisible), 57 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1086664 02/19/2015 10:03 PM
What is the best way to deal with the black primer that comes on replacement fenders? Just sand it and reprime the bare metal again? Is the black primer any good?
Builder #1086674 02/19/2015 10:30 PM
Builder,
That "black" primer you are referring to is actually an EDP coating. This coating is used to prevent rust. You don't have to remove this coating as it keeps the metal from rusting. My experience with this coating is to scuff it with 320 grit, primer it, let it dry, 400 grit, primer sealer, let it dry, 3m scuff pad, clean with tack cloth, then a grease and wax remover and tack again. Then paint it as you will.
Tim
1970 VW Beetle
I have seen too many EDP paint-over failures on the replacement parts available to us to trust leaving it on. The problems likely arise from improper metal prep prior to application. The symptoms which I have witnessed is the ability to scratch the paint off without much trouble. I would not want that to be the coating upon which I would put multiple layers of expensive paint.
I am not saying that ALL EDP primer is bad, just saying I have seen too many that were bad and led to stripping and repainting.
Carl
I agree with Carl to a certain extent. However, this "EDP" coating is very tough and prevents rust! If you sand it with 320 grit and the EDP coating doesn't come off the metal, then I would say you are not going to a paint peeling problem. On the other hand, the only time I have seen paint peel from the EDP coating itself is when it was NOT prepared properly. Also, keep in mind that all new cars have every body panel coated with it. This coating is what let the vehicle manufacturers offer 6/60,000 rust through protection, or better. Prior to that look at many cars of the 40's 50's and 60's that ended up looking like an ol' rusted out Schlitz beer cans.
1970 VW Beetle
the black finish seen on US OEM parts is EDP, the black finish on "offshore" repro parts might be anything except EDP, as fixit says, pretty easy to tell the difference, and if it's EDP, leave it be
