2 members (Rusty Rod, baldeagle), 91 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#1086111 02/17/2015 2:03 AM
I'm in the process of replacing all brake related components on my 1959 3/4 ton. Master cylinder, brake shoes, wheel cylinders, and brake lines.(hard and soft) Heres the issue; my supplier of the hard brake lines sent a complete set but the rear axle lines are 3/16. What is on there now are 1/4, is this going to be an issue? This is a 3/4 ton and all the stock lines are 1/4. Any thoughts on this? I guess i could put them one and see but wanted to try and save time and a brake fluid mess!
boomers59 #1086117 02/17/2015 2:16 AM
1/4" is fairly large. I think my 2 ton has 1/4" to the back and splits to 3/16" to each side.... Maybe. It's been a little while since I had those off. I'll check tomorrow.
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
boomers59 #1086224 02/17/2015 5:15 PM
The correct lines for the 3/4 truck are 1/4". Since the original lines are 1/4" and if the new wheel cylinders match the originals, the fittings on the 3/16" lines will be too small.
Have them send you the correct lines.
Fred
boomers59 #1091899 03/17/2015 12:11 PM
Any idea where i can get theses pre bent lines? Ecklers and Classic only offer 1/2 Ton, 3/16" lines.
boomers59 #1091976 03/17/2015 7:11 PM
Do the fittings work on the wheel cylinders? If you got a "KIT" and all the fittings match you will be just fine. If the line fittings don't match call the vendor and see what thy can do. They just might have a solution. Or they should take the kit back and refund the Dollars.
Steve H
boomers59 #1092107 03/18/2015 7:15 AM
3/16" is more standard for modern cars. That size tends to have a higher burst pressure, so it's used for disc brakes. 1/4" is fine for an all drum setup, but 3/16" works as well. If you want to use the brake lines you ordered, you should be able to find adapter fittings to make the 3/16" line work.
