0 members (),
78
12
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 66 | I'm in the process of replacing all brake related components on my 1959 3/4 ton. Master cylinder, brake shoes, wheel cylinders, and brake lines.(hard and soft) Heres the issue; my supplier of the hard brake lines sent a complete set but the rear axle lines are 3/16. What is on there now are 1/4, is this going to be an issue? This is a 3/4 ton and all the stock lines are 1/4. Any thoughts on this? I guess i could put them one and see but wanted to try and save time and a brake fluid mess! | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | 1/4" is fairly large. I think my 2 ton has 1/4" to the back and splits to 3/16" to each side.... Maybe. It's been a little while since I had those off. I'll check tomorrow. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The correct lines for the 3/4 truck are 1/4". Since the original lines are 1/4" and if the new wheel cylinders match the originals, the fittings on the 3/16" lines will be too small. Have them send you the correct lines. Fred
| | | | | Joined: May 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 66 | Any idea where i can get theses pre bent lines? Ecklers and Classic only offer 1/2 Ton, 3/16" lines. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Do the fittings work on the wheel cylinders? If you got a "KIT" and all the fittings match you will be just fine. If the line fittings don't match call the vendor and see what thy can do. They just might have a solution. Or they should take the kit back and refund the Dollars.
Steve H
| | | | | Joined: Aug 2014 Posts: 42 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 42 | 3/16" is more standard for modern cars. That size tends to have a higher burst pressure, so it's used for disc brakes. 1/4" is fine for an all drum setup, but 3/16" works as well. If you want to use the brake lines you ordered, you should be able to find adapter fittings to make the 3/16" line work. | | |
