1 members (1 invisible),
105
Mod | | | Forums66 Topics128,089 Posts1,056,440 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Anyone have a tip on this one? | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | I'm no expert, but I'd try getting the panel as straight as I could first, then address the crack with the MIG. Drilling the end of the crack is unnecessary. | | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | I 've never tried hammer welding fenders, I usually try to find good ones, till now, I've always lucked out.However, I hammer-weld alot of cracks or rips in large damaged saws at work. I work wth large band saws in a sawmill. I usually start at the last part of the crack, not where the crack is exposed to the edge.I weld about 1/8 -1/4" of the crack at a time .Then while the metal is still red or yellow ,I hammer it to shape using a hammer and dolly to the required shape and thickness(approximately).I then repeat this process until I get to the edge.Depending on the length of the tear is how long it will take .It usually takes 1-5 minutes. You can do this with carbon steal as well, I have welded leaf springs before ,but it takes one one treatment:Annealling. Any ways ,you can practice like I did 17 years ago to learn my trade by taking a piece of scap sheet metal and cutting fake tears into it and welding it back to original. After welding some people use a grinder to clean up the weld ,some people use a flapper wheel to dress the weld, I prefer the flapper. Caution, do not let the metal get hot while dressing the weld or it may crack. I always anneal after all welding to stop the cracking ,in case the rod Im using has carbon in it. To anneal, simply turn down the lights and bring the welded area to the dullest red glow,just so you can barely see it. Then try to hold that for a second and slowly take your torch away(take about a minute). Guess what, you are done. I know this will take practice, I had my share of cracks reopening. If you can master this,you'll save your self a lot of money and time. After a while you should be able to weld frames as well ,dress the weld ,and it should be invisible if done correctly. | | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | I forgot to mention,if you are using ox/ac, to get full penitration, so you don't have to weld both sides.As you have your puddle,just poke the inner flame thru the puddle ,quickly so that it closes again.This way you are applying heat once instead of twice ,if you did weld both sides.This takes practice ,but it is the better way to go ,once you can master that process. Lothar | | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | One more thing ,I found my FL fender=$5.00,FR fender for=$10.00,RR fender=$20.00, LR spare tirefender=$20.00 at antique car swapmeets over the last 3 years. So if you aren't in a hurry, go to the swapmeets , you may find what you want there for less than what you expect. | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Thanks for the tips, Killer and Chuck.
Despite the rip and dent, the fender is in OK shape...ok..it's a mess...but I'm going to give it a try. I think I can save it..I am an optimist....The Art Deco fenders are getting tough to find....the right rear are the worst...the vision on the right side is bad...everyone must have cut the corners and remodeled the fenders!!! | | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | take the fender lay it on flat cement use a wood block and hammer it will straighten out the crack will close then weld it or have it welded | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Very good discriptions on how to Killer.
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Sep 2004 Posts: 36 New Guy | | New Guy Joined: Sep 2004 Posts: 36 | If you choose to mig weld it. Here are my thoughts: 1. Scuff the area of the tear with a angle air tool and 36 grit wheel. 2. Hammer and dolly the fender back into place. 3. Clamp the tear so that you have a perfect butt joint. Remember, your butt joint ends should NOT touch. You should have about a 1/16th inch gap (about the same thickness of a cut-off wheel) which is filled with weld. A butt joint that is touching and welded WILL crack later. 4. Tack the tear as in the picture, about every inch. 5. Then go back and start to fill in the welds. All your welds should be spot welds but you can use a 1/4 inch or so of a bead weld. DO NOT be tempted to bead weld over a 1/2 inch at a time. That WILL cause the metal to warp. Put a couple in each gap (between the 1 inch gaps) and then immediately put a cold damp rag on the weld to cool it. Continue until the tear is completely welded. 6. When done, metal finish as usual. If you're on your mark, there should be no filling required. [img] http://www.redskyguideservice.com/MigWeld.jpg[/img]
1959 Chevy Apache Stepside 4x4 2009 Chevy Silverado 2500HD Duramax/Allison LB Crew Cab
| | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | Thanks Guys, this is good stuff!
Buddy | | | | | Joined: Sep 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 310 | Thanks guys, I learnt a lot just now, my fenders looked hopeless until I started reading this thread, now they look tough, but repairable. Any special hints for my patchwork ? [img] http://web.shockware.com/users/rosielle/images/ooopsifixedit.jpg[/img] Richard | | | | | Joined: Nov 2005 Posts: 146 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 146 | | | | | | Joined: Sep 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 310 | you should see the other one, this is the good one :rolleyes:  | | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | | | |
