| | | Forums66 Topics128,069 Posts1,055,886 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | So when it comes to door hinge bolts what kind of washers do you use, split ring or star type? Also will it matter if you use a bolt where the head is just a tad thicker than the original?
Thanks Joe | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | This site covers trucks from the '20s to the '70s. You need to be more specific. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | AD hinges take split washers on the door, and stars on the pillar. I don't know how much clearance room there is on the pillar bolts. They made them thin for a reason. Carl
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | External star washer You can use a thicker head bolt ...pic... ...pic... ...pic... | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I wonder why GM went with the skinny-headed bolts. They are a pain to take off when they are a little rusty, and are easily goobered up since they have less metal for the socket to grab. Carl
